393ci 6.0L heads, what should I make?
Heres the setup:
2002 Corvette Z06 block
Eagle 393 CI forged 4340 crankshaft
Eagle 4340 forged H-Beam rods
Block is clearanced for .700 lift camshaft
Ross racing pistons
Compression ration is 11.2:1
Ported and polished W2W LS6 oil pump
LS6 intake manifold
SLP lid K&N filter
Z06 85 mm MAF
28# injectors
255 Walbro in tank pump
Ported and polished 6.0 liter heads cast number 317
Heads flowed 329 @ .600 lift
Comp Type R lifters
Comp springs
Comp TI retainers
Comp Cams 228/230 571/573 112 LSA camshaft
Ferrea 2.02 1.60 valves
Heads are fully worked
Pacesetter Coated Long tube headers
3" y pipe
Center mount exhaust from SLP
All tuned by HPTuners to a safer say 12.8 tune?
Ross racing pistons
LS6 intake manifold
SLP lid K&N filter
Z06 85 mm MAF
28# injectors
Comp Type R lifters
Comp springs
Comp TI retainers
3" y pipe
