372 RWHP here, what gives?
The 472 was with the Juice but the converter was not locked at that time. Unlocked on the motor was 351 rwhp best
Also, lots o folks will say dont worry bout the #'s esp. on an A4. Just get it to the track and see what it traps at, thats the real indication of power
What kind of exhaust do you have, is it the Flowmaster catback? Have cats?
Weather was beautiful, about 75 degrees, the numbers were corrected to sea level.
True about the track stuff. Have yet to go to the track. I need to get a set of tires for it. It does pull as good now as it did before the cam install with the juice on it. Now with the juice, holly **** does it run!
Also, now that I have idled the car up to 900 rpm and it runs alittle higher rpm down the road due to the 3.73 gears, I guess I could benifit from an UD Pulley without hurting anything else.
I"ve heard they do good exhaust work so I figured I would ask.
I still need to get back over there to dyno again soon before I start tuning mine.
It is loud but flows badly.UD pulley 5-10hp. Allthe little stuff adds up
