6.0 + 244/248... hp/tq predictions?
I sadly did not have enough time to dyno my car after I completed my 6.0 swap a couple weeks ago. I had to leave for CA for a job this summer before I got a chance to get it to a dyno or anything. So I'm pretty curious as to what I should be putting down with my setup once tuned. Here is what I have:
6.0 iron block bored .060 over
317 LQ9 heads with PRC dual spring kit
244/248 .635/.627 112 w/ 4 degrees advance ground in
Ported LS6 pump, double roller, etc
LS6 intake
Ported TB
March U/D Pulley
Gran. 85mm MAF
Lid + K&N
SLP CAI
Hooker shorties
SLP Y-pipe
LM exhaust
A/C belt disconnected for the time being.
It's an M6 with stock gears. It was really bogging down when I was driving it around a bit before I left. It's still the stock 5.7 tuning so it's pretty damn confused, but every once in a while it would get its **** together and really pull hard. Just curious as to what I can look forward to put down when I get back
LS6 intake
Ported TB
March U/D Pulley
Gran. 85mm MAF
Lid + K&N
SLP CAI
Hooker shorties
SLP Y-pipe
LM exhaust
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
I think you might want to put the stock maf back in and get some long tubes and a dual exhaust to get the max power, and get it tuned. With the stock tune and what you have, I would guess around 375 rwhp, but with a tune and the extras I listed, you will improve drastically. Probably another 100 hp. You will also need a 12-bolt and some 4.10's or 4.56's.
I'll throw my 2 cents:
Assuming 11.1cr, 445rwhp/435rwtq once tuned. IMO you will have a strong midrange but a tq curve that will fall early due to the shorties.
Well if the heads are stock and you have shorties I am gonna say you will dyno around 415-425 after its tuned.
Your gonna kill power due to lack of compression.
Your going to have a 375 cubic inch motor but only 10:1 CR if your using a 72cc head and stock head gaskets. That is not so great.
I would save up some cash have the heads ported and milled down to about 68cc's. Flycut the pistons if they aren't already done, use a .045 head gasket, add a good exhaust setup and have a 500HP car. I am guessing by your post that your heads are stock. Open them up to a 4.060 bore run a 4.100 head gasket will make a difference by itsself.
I'm running cometic .045 head gaskets at 4.100 right now. How much would it run me to port my heads to 4.060 bore like you said? Also, would I want to mill them at the same time? What would you suggest? By the way, my pistons have -2cc reliefs cut in them already.
