A/F 13.9 how to correct?
Old Jun 3, 2005 | 11:25 AM
DriBak's Avatar
Default A/F 13.9 how to correct?
My dyno run put me at 300 HP 327 ft/lb torque and A/F 13.9 tech said I was WAY lean what do I need to do to correct or adjust.
Car is 2000 A4 with lid, cut out, K&N, and FRA
Old Jun 3, 2005 | 11:41 AM
97bowtie's Avatar
You'll need to get the car dyno tuned...either by a shop, a board member or buy the software yourself.
www.hptuners.com
http://www.carputing.com/
Old Jun 3, 2005 | 12:40 PM
_HAVOC_'s Avatar
IMO 13.9 is a bit lean, but definitley not WAY lean. on motor I like to be at 13.2-13.4
Old Jun 4, 2005 | 08:57 AM
obZidian's Avatar
13.9 isnt that lean...its just close....im close to 13.3-3.5 and as low as 12.9 you should be fine but if you wish, you could always have it dropped for peace of mind. You will need someone with tuning capabilities to help you out.
good luck!!
Old Jun 5, 2005 | 06:51 AM
YO-EL's Avatar
Adding fuel (programming) will richen it up.
