Anyone know what could be causing this?
Old Jun 19, 2005 | 03:05 AM
Not a 350's Avatar
Default Anyone know what could be causing this?
Seems like the car is getting enough fuel...
This is a '97 LT1, LT4 hot cam, 1.6rr's LT headers, CA, exhaust, regualr bolt ons. The problem gets worse as the car gets warmer.
http://www.ctbasses.com/misc/run02.jpg - baseline
http://www.ctbasses.com/misc/run03.jpg - more fuel
http://www.ctbasses.com/misc/run04.jpg - more fuel
http://www.ctbasses.com/misc/run05.jpg - less fuel
-Aaron
Old Jun 19, 2005 | 09:47 AM
lilbuddy1587's Avatar
looks like massive KR(knock retard) Do you have the lt4 knock module ?
Old Jun 19, 2005 | 09:42 PM
Not a 350's Avatar
Yes, I have the LT4 knock module in the computer. The Knock sensor itself came on the '97 motor and the computer was a 95 Caprice computer tuned by Ed Wright to work with this one. I think the computer and the knock sensor should sink fine, right?
-Aaron
Old Jun 20, 2005 | 02:54 AM
Not a 350's Avatar
Default For easier viewing...
Maybe it will be easier if I attach the graphs.
Attached Thumbnails Anyone know what could be causing this?-run02.jpg   Anyone know what could be causing this?-run03.jpg   Anyone know what could be causing this?-run04.jpg   Anyone know what could be causing this?-run05.jpg
Old Jun 21, 2005 | 04:24 AM
Not a 350's Avatar
Unplugged the knock sensor and took it for another spin. It still hesitates when warm in high gear...
-Aaron
Old Jun 21, 2005 | 06:17 AM
92SilverSHO's Avatar
do you have a good fuel system? buddy has a 96lt1, head and cam, had to change out the fuel pump and injectors and get it retuned, problem solved, it was leaning out to much in higher rpms.
Old Jun 21, 2005 | 03:46 PM
Not a 350's Avatar
Yeah, 255lph pump and 30# injectors. The A/F curve on the graph is flat at 13.0 for the whole run (see run #3)
-Aaron
