How much RWHP and Torque
I have purchased (And not installed yet) the following mods to my 2002 Z06:
G5X-2 112 LSA
AFR 205 Milled to 61ccLG Long Tube Headers
ASP underdrive Pulley
Vararam Intake
Comp R Lifters
SVO #32 Injectors
Jwiss
Corsa Exhaust
160 Thermostat
How much RWHP and RW Torque can I expect (I do not have to flycut the pistons as the gasket is .045 and the heads are milled to 61cc for 11:1 compression). I was shooting for 440 RWHP and 410 RW Torque. Anyone have a similar setup?
JG853
G5X-2 112 LSA
Vararam Intake
Comp R Lifters
SVO #32 Injectors
Jwiss
Corsa Exhaust
160 Thermostat
JG853
You will hit it... I did....
JG853 i'd check ptv clearance if i were you. just for reference another member recently did a similar setup except the 205's were milled to a 59cc chamber and the x2 112 and there flycuts were ~.075
I spoke with Lou at LG and he gave me the set-up. The AFR's at 59cc, you are correct, I would have to mill the Pistons. However, at 61cc and a .045 gasket, Lou told me that I will be fine. I did not want to flycut the pistons so I went with 61cc and still get 11:1 compression. Thanks for the resonse.
