dyno'd today
This is through 4.10's and very heavy wheels as well, heads/cam in sig.
also can you post up all your previous dynographs and setups? you did previously run a PP ls6 style combo right, then picked up ~18rwhp or something with the out the box 205's unmilled with less compression then the PP's.
from what i remember your car has never been a dyno queen so it doesnt suprise me you didnt hit 450rwhp even with every concievable bolt on. im more curious of the overall power curves of your 3 setups then peak hp/tq.
as far as tuning Don knows what he's doing, and magnaflow cats flow quite well.
probaby could of made the same power with the old combo and just milled the 205's, run the cometics, and kept the FM11...
QUOTE]
don has all my graphs on his computer at work. maybe i can get him to put them up
TEA ran there stage 2.5 program through the heads
car is not running that great now even after the tune. i hope the idle relearns itself. im stalling at every light
.jpg)
I know they can adjust the t-body w/ LS edit but I swear by the drilling the hole method. It just flat out works perfect, it keeps your idle down too (mine is @ 850) it was my best mod to date as far as an improvement over the stalling I encountered after I did my cam/headers. Also could it be the N/W in conjunction with your combo? I know they are thee best C5 T-body but many T-body porters have difficulty with the C5 T-body. Also what about the FAST intake is it possible it is allowing umetered air due to poor fitiment ?
(I would gamble that if you switched back the the LS6 Intake & a shaner or stock t-body you would run better and post better numbers -- just a hunch based on your current numbers)
im at 3/4 turn at zero lash
That is exactly where I am at with the factory rockers....
We made alot of pulls that day varying timing/A/F across the board.The A/F was at 13-1 across on many pulls.Timing was varied from 22-30 degree's with very similar results.Which means that is all the combo would make OR there is a restriction somewhere which I would point towards the exhaust setup
Keep in mind my dyno is not forgiving on dyno #'s and I DO NOT fluff them
His car sit's to run a very low 11 on street tires.
