Diff between 28" slicks and street tires on the dyno
Have a customer that only dynos with slicks on, and he was wondering what the difference would be using regular street tires instead of 28" ET Drags. Is it like a 20 rwhp difference? We had them set at 14 lbs pressure on the dyno FWIW.
Hey Ryan... Allan said he see's slicks consistently dyno lower than radials.... couldn't explain why though. On the last set up, he said I'd see ~ 10-12 more rwhp with the same gear(4.10's at the time)on 26" radials verses the old 26" ET Streets.
Wonder what I'm loosing w/the 28"ers on a 4.56?
Still 'bout half tempted to swap in/dyno a 10 bolt/3.42's and radials w/this combo for the "internet" #'s
i gained 14 rwhp going from et drags to nittos. drags were at 15 psi nittos at around 25 psi
same exact wheels (prostars) - just remember that wheel weight has to do with it too. not many have done a true test like i did eliminating the wheel as a variable. this was on a 340 rwhp car.
Originally Posted by Damian
We'd call you Gomer #2
I've seen about 5-7 rwhp on my car by going from the 17x11's and 315/35/17's to a 16x8 and 245/50/16 nittos on the dyno.. same day testing.
Thats why I own a Dynapack, tuning without the tire variable. Much more accurate.
With a dynojet, anything can change the rate of acceleration. Tie down pressure, tire pressure, tire size, tire width, ect.
Rick
Rick
Rick
