How Much Does Wheels/Gear Cost You?
now, about the .1 gain. there are a couple of things to take into consideration. stock motor and having to shift into 4th. stock motor peaks out at 6100ish. so, i have to rev past peak to try and delay the shift into 4th as much as possible. that and 4th gear dragging the motor down is what's costing me so ET.
but, i bought for the end result. why buy 3.73 now, when i'll need 4.10 once i do heads and cam. why buy twice. i take the hit now to spend less money down the road.
auto -------- 3.23 ----- 4.10
1st 3.06 ---- 9.88 ---- 12.54
2nd 1.62 ---- 5.23 ----- 6.64
3rd 1.00 ---- 3.23 ----- 4.10
4th 0.70 ---- 2.26 ----- 2.87
you can see what you effective rear gear ratio is. the whole 10 speed bike thing. you can come out of the hole WAY quicker with a 12.54 gear than a 9.88 gear.
Once I add a cam it will be a different story, I could raise the rev limiter to 6500-6700rpm and the redline would be at 122-125mph in 4th gear and with 150shot I don't think I will have to shift into 5th.
your kinda like an auto with 2.73 gears. shifting into 3rd (1:1) right before the traps.
What do usually cars with 530-560whp trap at?
The car has changed to this:
Heads/Cam/Induction:
TEA Stage 1.5 5.3 Heads Milled 0.010
Comp Cams XE 228/230/571/573 LSA 112
85mm Lid
85mm Maf
Rollmaster Double Timing Chain
Ported Oil Pump
Fast 90mm Intake
Nick Williams 90mm TB
MSD 8.5 mm Wires w/ TR55 Plugs
0.045 Cometics Head Gaskets
Kooks 1 3/4 Stainless Steel Race Headers
Kooks Y Pipe
4200/2.35 STR Stall
B&M Deep Tranny Pan
Motive 373's/TA Girdle/Stud Kit
BMR LCA Relocation Brackets
Koni SA's
35 mm Front/22 mm Rear Sway Bars
Single Adjustable LCA's
Single Adjustable Panhard Bar
Comp 7.4 Hardened Pushrods
ASP Under Drive Crank Pulley
SLP Dual/Dual Catback Exhaust
Flowtech Cutout with McCord Power Plate
K&N Air Filter
Fast Toys Ram Air
B&M 24K Cooler (Mounted under frontend)
BMR SFC's,
BMR STB
Tunnel Brace
Extend your rev-limiter if your valvetrain and bottom end allow it.
