How Much Does Wheels/Gear Cost You?
I had my 3.23 upgraded to 3.73 for $450.00 and it included bearings and gear and pinion seal leak being fixed, so all labor and materials.
The wheels...
American Racing TTIIs I got Discount Tire to go 963.00 for all 4 rims.
Hope that helps a little.
auto = 3rd gear
manual = 4th gear
the reason you dyno in the 1:1 gear in the trans is to remove the trans variance
that way crank to trans output is 1:1.
and it's the opposite here also. the lower trans gear will produce less power because it's a higher numerical gearing. just like the gear swap in the rear end.
here's two dynos from my car. same day. 2nd gear and third gear runs. compare blue lines to blue lines. red lines to red lines.
2nd gear runs
3rd gear runs
Also, I don't understand how the power is lost with different gears. Engine is producing the same amount of power and it's being transfered to the wheels. So, how's changing rear end gears lower the over all amount of power being transfered from the engine to the wheels? Just doesn't make sense to me for some reason. And if we were really to lose that power with gears, how do the cars become quicker at the track?
now torque is what makes horsepower. it takes less torque to rotate 4.10 gears versus 3.23 gears. less torque calculates to less horsepower.
I went to your web site and saw your car and dynos with time slips, how much faster did ya run with 4.10s over your 3.23s?
i had more mph in the 1/8 and slightly less in the 1/4 comparing 3.23 to 4.10 gears. seeing these timeslips will help you to see the mechanical advantage of higher numerical gears.
3.23 gears timeslip
60 ft --- 1.842
1/8 ---- 7.599
mph --- 93.58
1/4 --- 11.783
mph -- 117.93
4.10 timeslip
60ft --- 1.709
1/8 ---- 7.500
mph --- 94.05
1/4 --- 11.664
mph -- 117.67
thing to note: this is with a completely stock motor. from TB to cats. if i had a cam that had a range of, say, 3000-7000 instead of idle - 6000, there would be more of a difference.
I also see that you gained a very decent amount N/A with the gears.
