Quick question please
Old Sep 4, 2005 | 02:51 AM
LS1FIRE's Avatar
Default Quick question please
Might be a stupid question but i would like know what is the difference from std numbers to sae? And what do they mean? Do they dyno higher then each other? Thanks
Old Sep 4, 2005 | 07:33 PM
krexken's Avatar
Both are correction factors used when dynoing. They are used to keep dyno readings comparable when different dynos are used or when dynoing in different weather conditions. Ideally you should get the same results no matter what the weather conditions are. SAE numbers and std readings are usually different because I think they both used different correction factors.
Old Sep 4, 2005 | 09:17 PM
DynoDR's Avatar
Try this.
http://www.land-and-sea.com/dyno-tec...horsepower.htm
Old Sep 5, 2005 | 12:15 AM
LS1FIRE's Avatar
Thanks
