572rwhp 408 N/A
Old Sep 26, 2005 | 10:50 AM
LOnSLO's Avatar
Default 572rwhp 408 N/A
Got the car retuned last Thursday night for a local track event. I swapped cams again to a 248/258 .646 lift Comp cam. Also changed the intake over to the GMPP single plane with Accel TB. First pull untuned netted 548rwhp!! After three pulls, we got it up to 572! Rwtq was right at 485. I don't have a graph to scan, since it was so late when we got it done I didn't feel like printing out a graph and all that, since normally I don't care about dyno numbers. Runs were through a 9" rear with 4.56 gears and 28" Hoosier slicks. Classic on this board did ALL the tuning.
Old Sep 26, 2005 | 10:54 AM
383ss's Avatar
damn nice. could you please post a graph?? where did it peak at? what heads? I assume this was hydraulic?
Old Sep 26, 2005 | 10:59 AM
T/A KID's Avatar
Very nice, whats heads you using and what is the rest of your setup. I like the single plain intakes. You using a elbow and TB I persume. What size TB 90-105MM. Does yours fit under the hood.
I myself am doing a similiar build up for my car, Using a Converted Super Vic with a 100 degree elbow matted to a 90MM TB with ported AFR heads and a mid to high 230 duration cam, supporting mods should do 500RWHP on the dyno in my 396 LT4.
Old Sep 26, 2005 | 11:02 AM
Ben R's Avatar
Very nice.
Old Sep 26, 2005 | 11:11 AM
LOnSLO's Avatar
I have no way to post a graph up. I am using some 5 year old MTI stage 3 LS6 heads, and yes, this is a hydraulic cam. The TB is a 1500cfm Accel 4150 style mounted directly onto the intake. I may cut to make room for a 2" spacer.
Old Sep 26, 2005 | 11:22 AM
2001 Pewter WS6's Avatar
Restricted User
Sounds awsome... Pics of the setup would be nica as well...
Old Sep 26, 2005 | 11:29 AM
VINCE's Avatar
Shorty Director
Someone finally beat my numbers? Wow!!! Can you post a picture of this Intake and TB? I have never heard of it. Also, are your #'s STD or SAE?
Old Sep 26, 2005 | 11:41 AM
KAOS's Avatar
i started a post earlier about 600rwhp with a hydraulic setup, you are so close. keep it up. anything else you can do to get those numbers up? new AFR/TEA heads maybe? that would rock
Old Sep 26, 2005 | 11:50 AM
LOnSLO's Avatar
SAE. I'll try and snap a pic or two tonight.
LOnSLO's Avatar
I just need a 10 bolt and street tires to hit 600
Old Sep 26, 2005 | 01:15 PM
383ss's Avatar
I don't know about that, I gained hp going to 28" slicks on the dyno.
Old Sep 26, 2005 | 01:18 PM
LOnSLO's Avatar
With my last setup, I lost 36rwhp going to a 9" and slicks from 10 bolt and street tires.
Old Sep 26, 2005 | 01:26 PM
Got Me SOM's Avatar
what compression are you? This has to be a high compression motor.
throw the spray on there and you have a potential 145-150 mph trapping car.
Old Sep 26, 2005 | 02:51 PM
LOnSLO's Avatar
Little less than 12:1.
Old Sep 26, 2005 | 06:17 PM
Hardtop's Avatar
Awsome numbers, congrats.
Bruce
Old Sep 26, 2005 | 06:50 PM
Classic's Avatar
Nice numbers The TB is a carb style TB -- not an elbow setup. The whole motor is probably one of the cleanest nicest looking around.
Old Sep 26, 2005 | 07:27 PM
SPANKY LS1's Avatar
Post up some pics if you get a chance, I'd like to see it.
Also, are you using the stock PCM and tuning in SD, or are you using BS3, DFI, etc?
Nics numbers, Shawn
Old Sep 26, 2005 | 07:46 PM
Classic's Avatar
Its a stock computer, no MAF.
Old Sep 26, 2005 | 08:24 PM
Jason99T/A's Avatar
I can shift faster than you.
Nice job Ryan! Nice #s through your drivetrain!
What made you go back to the hydraulic roller?
Jason
Old Sep 26, 2005 | 08:36 PM
LOnSLO's Avatar
Jason
Thanks Jason. Got tired of floating valves with the other stuff. The heads I'm using won't let me put a larger spring on there, so I went back to hydraulic. It's only temporary though
