Another AFR 205 "Mamo Combo"
#41
Originally Posted by Tony Mamo @ AFR
![Icondrool](https://ls1tech.com/forums/images/smilies2/icondrool.gif)
I told you to end your suffering months ago....flex that plutonium card a little!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
lol
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
I have been flexing it.... new furniture for the girl's rooms... Porter Cable Polisher for me... breast augmentation for my evil half... I am tapped out...
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
#42
Originally Posted by SideStep
breast augmentation for my evil half...I am tapped out
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Your excused....forget the FAST!
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#43
Originally Posted by 71CamaroLS1
- Comp XER 224/228, 114 LSA, Comp R lifters (at 1.25 turn preload per Tony), .
Am I reading the preload right? I thought those things were pretty touchy on the preload? Seems like alot of people were only going 1/8 turn, or so, to get good results.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#45
Originally Posted by blackz93
Am I reading the preload right? I thought those things were pretty touchy on the preload? Seems like alot of people were only going 1/8 turn, or so, to get good results. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
https://ls1tech.com/forums/showthrea...R+preload+mamo
I found that setting the Comp Rs to .010 preload cold, as recommended, led to a very noisy valvetrain (noisier than my solid roller big block!). So after reading the thread above, I cranked them down to 1.25 turns, which quieted things a lot (still noisier than stock, though). The dyno runs were made with the 1.25 turn setting.
I don't know what difference a stock replacement lifter would make. I know that Comp Rs are designed with tighter clearances, so as not to "pump down" so much with fast ramps and heavy valve springs. I used the upgraded AFR springs, which I would recommend. I would bet that a substantial number of "disappointing" results from LS1 combos come from poor valvetrain control, leading to valve bounce. For whatever reason, the HR cams available for LS1s seem to be the most aggressive lobes available for any HR motor, putting a premium on valve control.
#46
nice numbers i wish i could afford a set of afr heads but i got a set of patroit heads which work awsome on my car bringing 456hp and 431ft trq threw speed density tuned by rick@synergy motorsports.i got a fast90/90 combo but in progress of installing wish i could afford mamo to port it for me but don't have the money so cartek is doing it.Which cartek is very good also.
well congrats on #s
well congrats on #s
