MTI STG 2e & G1 Cam LOW DYNO NUMBERS, why???
The dyno line looks smooth enough. Are you averse to leaning the AFRs out to say 13.2 in the high rpms and 13.8-14 in the low rpms, transitioning in gradient steps? This will get you a little more HP.
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
Maybe a few more but it's down at least 20 HP & TQ across the board.
N/A you want 12.7 - 12.8 on the dyno any higher than you take a chance of getting knock. I have seen this many times on the dyno.
On the street you will be about .2 - .3 leaner, a dyno just can't load a car like the real world does.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I am running 13.6-13.8 all day long (through the summer, 4 months). The most KR I have ever recorded was .5 and I cannot get it to repeat with any significance. I am also running 26-28 degrees of timing in the high-rpms, a little more in the lower rpms. I have a DynoJet WB installed and I never see more then .2 difference (if that) in my dyno AFRs and street AFRs.
LS1 Tech Administrator
Often, sticking the Dynojet sampling tube up the tailpipe of a car gives a leaner reading than what's actually taking place. Sometimes as much as a full point lean. So if you target a 12.7 A/R ratio on the dyno, you may actually be giving the car 11.7 A/F ratio.
Try giving the car what it likes and see where you are. You may find that leaning the car will pick up some extra power.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I have the G1 and AFR's, I'll post numbers once I get it tuned, I had one trip to the track since installation and it sucked. I hope this cam is not a flop! I swapped from the X1 for it, the X1 had too much lift for my milled AFR's.
Geeze, I hope I don't have to swap cams again.....
Anyone else have disapoionting numbers with this cam?
Originally Posted by 1BadMoFo
I stand corrected
Please post your full list of mods, great numbers through cats, and especially if you don't have other things, such as a pulley...
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
