14:1 afr to lean?
Old Sep 29, 2005 | 02:55 PM
98redorangeta's Avatar
Default 14:1 afr to lean?
Today i was on the dyno with my friends car and we only got 349hp 350TQ out of a 99 TA WS6 with patriot heads and 226/226 585 lift patriot cam. We ended the day on a run that left the car with a 14:1 afr witch i thought was kind of lean especially since i see a lot of guys with much lower afr this was threw an A4 with 3500 stall but i still think the numbers should be higher. Should adding some fule net better numbers?
Old Sep 29, 2005 | 03:03 PM
MARKSZ71's Avatar
i did 400rwhp with a 4000 stall and prc heads,and a 226 cam
Old Sep 29, 2005 | 03:10 PM
NOSjohn's Avatar
Restricted User
Yes, I would try to get it around 12.5 - 12.8:1.
Old Sep 29, 2005 | 03:23 PM
Mike @ New Era's Avatar
That is too lean , did it log any knock retard ?? Should be between 12.8 - 13.1 afr on that set up , just my 2 cents .
Old Sep 29, 2005 | 04:45 PM
gollum's Avatar
My AFR has been 14.1 for two years now with no problems. But I will soon tune it to 13.0-13.7
Factory LSX cars are set to 14.7 cruise, and 13.7 wide open throttle.
Old Sep 29, 2005 | 05:04 PM
Mike TexaSS's Avatar
8 Sec Tuner
Ive yet to see any stock tune be 13.7 at WOT.
The norm is 12.0-12.5..
Old Sep 29, 2005 | 05:17 PM
gollum's Avatar
Inaccurate Wide Band maybe?
Old Sep 29, 2005 | 05:48 PM
dennsterTA's Avatar
my car runs 13.6 WOT stock.Thats what iv heard the norm is for stock...at least i hope thats right. 14:1 does seem a little to lean.
Old Sep 29, 2005 | 06:55 PM
black_z's Avatar
Any exhaust leaks?
Old Sep 30, 2005 | 11:11 AM
I thoght it was a lean i had him at 12.8 on the first pull and the guys at the dyno told me to lean it up. We ended up with 14 i would have brought it to maby 13 because he does have stock injectors and they do some times hit 20 ms wich has to be about maxed out. Also there equipment did start to give wavy afr at the end of the day so they could of been having some problems with there equipment. There are no exaust leakes that we know of. Thanks for the help and i will try to get the graph from my friend to post it
Old Oct 2, 2005 | 09:27 AM
damon_Z's Avatar
I'll back you up on that, because mine was a 12:1 with the only modification (if you even call that a modification) being the NGK TR-55's. It also makes sense, because wouldn't the factory want your cats to last as long as possible?
Old Oct 2, 2005 | 12:10 PM
loreak's Avatar
my car was 12.2:1 when it was bone stock, now after intake mods etc its up close to 14:1
Old Oct 2, 2005 | 12:17 PM
damon_Z's Avatar
Interesting. I'm about to get an SLP lid and the SSRA2 installed so I guess I should expect mine to shoot up to 14:1 also. I just wonder where the a/f will fall to once longtube headers and y-pipe with cats are installed...
