New Dyno Numbers
Old Oct 5, 2005 | 11:33 PM
camaro98z28's Avatar
Default New Dyno Numbers
Well I think they are good numbers
With a G5X3 114 LSA, TEA 1.5 Heads and an APE Block 348ci
426RWHP and 367RWTQ
Tuned for a 150 Shot and has a 3600 Yank Extreme Stall
Drives great and pulls hard
My old numbers were with a stock stall and much cooler out.
Thanks to Mike at AZ POWER & SOUND and NIC the Tune Master
Old Oct 6, 2005 | 07:23 AM
Ben01C5's Avatar
Got a graph? Only 20rwtq with the addition of heads and cam?
Old Oct 6, 2005 | 07:40 AM
V-seriesTech's Avatar
426RWHP and 367RWTQ
Not bad at all man,..considering its an automatic with a larger stall....
Old Oct 6, 2005 | 08:23 AM
ArticZ's Avatar
Jeff you down tuned it for emisions right?...lol...nice numbers man..
Old Oct 6, 2005 | 05:19 PM
H/C LS6Z's Avatar
Good HP #'s but torque seems a little low.
Still not to shappy though, congrats
Old Oct 6, 2005 | 11:13 PM
I never dynoed with the 3600 stall before but I hear that you can lose on the TQ side.
I will see if Mike at AZ Power and Sound will post the graph or NIC
Old Oct 7, 2005 | 10:04 AM
Found a problem so I might just Dyno more now.. Only running on 7 cylinders maybe 6
Old Oct 8, 2005 | 03:06 PM
o2bird's Avatar
BWHAHAHAHAHAHAHAHHAAHAHAHHAHAHAHAHHAHA!
Old Oct 9, 2005 | 02:47 AM
WOW even more problems..
Old Oct 9, 2005 | 02:57 AM
o2bird's Avatar
Yea. I say that right there pretty much sums up the night.
Old Oct 9, 2005 | 03:22 AM
99BackNBlackZ28's Avatar
Wow dude, they really did a number on that car. I've never heard of so many issues taking a car in to have a new motor swapped in & the car coming out w/parts missing, things not tightened down, broken ****. I hope you're able to recoup your losses from them.
Old Oct 9, 2005 | 03:23 AM
I wasn't too thrilled w/my cam-only tq #'s w/my 3200 stall. Oh well.
Old Oct 9, 2005 | 12:07 PM
Yeah, I just turned a corner and the engine started to knock. Sounds like a lifter so I dont know.
Old Oct 10, 2005 | 01:34 PM
Orange Peel's Avatar
Wow, sucks to hear this Jeff, was all the issues from Mike or the engine builder who redid the APE motor?? Made good power to start at least
Old Oct 10, 2005 | 05:48 PM
AZ Power & Sound's Avatar
This will be the 3rd APE engine / paperweight on our floor... They came assembled so installation error cannot be at fault
Old Oct 10, 2005 | 06:51 PM
I thought you guys sent the engine out to be looked over/redone? Maybe I was told wrong, but it doesn't suprise me, I thought to myself, there's no way Jeff would just install that engine KNOWING that APE has been putting out crap engines
Old Oct 10, 2005 | 07:01 PM
the cam bearings were bad in both his engine, and another APE 402 we just had that sheered a cam gear off the cam. A local machine shop replaced the cam bearings, above and beyond that its whatever the previous owner of the engine had them do. It was a used engine sold as-is as far as I know...
Old Oct 10, 2005 | 07:10 PM
verbs's Avatar
The cam bearings were a tad worn; the engine builder I sent them to said it was normal on LS1s, but just in case I had em replaced anyway before sending the motor to Jeff.
The motor NEVER had a knock when it was in my car. Regardless, if there is a problem, being that Jeff just got this motor, I'll work with him to make sure it get's fixed up right.
Old Oct 10, 2005 | 07:16 PM
verbs's Avatar
Going out of your way to bash a little eh? You make it sound like there were a plethora of parts missing; one aftermarket spark plug wire being swapped for a stocker doesn't qualify as such. As far as anything being broken, if there is anything broken, it's the motor and has nothing to do with the installer. There are no "losses" that have been caused by the installer so please quit trying to place blame on them.
Old Oct 11, 2005 | 12:01 AM
From what I was told there was a laundry list of things that were wrong w/the car when Jeff got it home & looked it over, which was before any mention of a "knock" or whatever the hell is wrong w/the motor. But because you say so, evidently all that info is wrong.
