do these numbers seem correct at the strip
Reaction-1.4369
60foot-2.1633
330foot-6.1051
1/8 ET-9.2728
1/8MPH-78.45
1000ET-11.9402
1/4ET-14.2132
1/4MPH-97.42
any input to as if you think the car is not right or if it was the spinning through second gear that made these times
If your spinning that much you need some new rubber.But i think that your mph is consistant w/your mph.
IMO even spinning that's kinda slow.
We'll wait for more input,some guys on here really no there ****!
Your 60 ft is actually decent considering its an M6 on street radials.
Are you certain your clutch isn't slipping. I don't see how you could maintain 5500 all the way through second gear, it should hook eventually, granted you get all of first gear and arent going like 5 mph. Unless your clutch just isn't holding.
For comparison, my car went 12.7x @ 113.xx on a 2.15, and 88 or so in the 8th. I shift pretty hard into second and it spun the tires for a bit, but then hooked and went. (Not good tires either, that was actually the best short time I've had yet.)
If your not breaking loose at the top of first or during the launch, but then through all of 2nd, might be something else wrong.
Sometimes when you add headers, other problems show up, sometimes tuning related. With as minimal engine work done, I wouldn't think a tune would be needed, are there any codes stored in the PCM or anything else weird going on? Has it been on a dyno recently? Could be fuel related also.
BTW, are you on anythingcars.com too? I have the same username there too.
I think you need a set of drag radials, your suspension mods are probably just planting the street tires too much causing extra problems.. I ran the times in my sig at the same track on DR's.. with stock suspension, stock weight and stock rearend.
I've probably seen you at Penwell before, I go all the time..
I would double check your cluch also i have a spec 3 now but i bought a spec 2 plus series i'm going to install when this goes.The spec 2 plus gives alot less chatter plus the ability to hold 630ft lbs of torque!
My advice to you is drag radials and practice practice practice, I don't really think springs with help you with your current setup.
Jon
