AFR heads plus "baby" 222/224 cam
Old 10-26-2005, 10:20 PM
eb02z06's Avatar
These AFR's really shine guys-they work well with almost any cam!
Old 10-27-2005, 03:24 PM
gnx7's Avatar
You are telling me you put down 440rwhp/405rwtq and went 130mph at lets say 3300lbs with driver....
The numbers don't add up with 22* timing etc....
I have a 2950lb car with driver (LS1/RX-7) and didn't powershift and went 124mph on 91 octane and 26*. With powershifting and bumping up the timing it will most likely go 128mphish. 439rwhp/385rwtq.
I have stock '99 shortblock, flycut pistons, .024" milled AFR's, MLS gaskets, stock LS6 intake, ported TB, TSP 233/239 .600" 112LSA cam, Fidanza alum, RAM910, 1 7/8" longtubes with Magnaflow 3" hi flow cats, Xpipe and true 3" duals into Magnaflow muffs and T56/3:90's.
What weight is your Vette with driver?
I'm not doubting your dyno numbers... it is the mph that doesn't jive.
-Mark
Old 10-27-2005, 03:37 PM
eb02z06's Avatar
Dude where did you get I went 130? I have yet to go to the track this year?
Old 10-27-2005, 04:02 PM
LS1 Tech Administrator
Patrick G's Avatar
Post #6 Vortech said: "The Cartek cam is just a tad bigger than this one but has really proven itself at the track running as fast as 10.60's@130!"
I believe he was referring to Cartek going 130 with the cam he chose.
Old 10-27-2005, 04:19 PM
JS
JS's Avatar
Well that 130 MPH was also in very very good air (-2000 DA)
Old 10-27-2005, 07:16 PM
eb02z06's Avatar
I think Brent was making like 480 rwhp-nonetheless his car was very impressive.
Old 10-30-2005, 07:51 AM
FDLS1's Avatar
nice #'s , Who does your tuning? I am in the Toronto area and looking for a good Tune come spring, who do you recomend?
Old 10-30-2005, 10:10 AM
eb02z06's Avatar
I do all my own tuning-pm me and maybe we can work something out.
Old 10-31-2005, 05:49 PM
pdd
pdd's Avatar
sounds like a sweet setup
Old 11-01-2005, 04:23 AM
ChiefDave's Avatar
Nice numbers! I'd like to see what you gained at the track too.
Dave
Old 11-01-2005, 07:19 AM
eb02z06's Avatar
I went to the track the past weekend with the 2x cam which made similar power-however I did not get any good runs-either I bogged or i killed the tires-then I broke my output shaft.
Quick Reply: AFR heads plus "baby" 222/224 cam
