LS2 vs Fast 90 dyno comparison
Old Aug 10, 2006 | 11:36 PM
  #61
smokemup's Avatar
Originally Posted by Tony Mamo @ AFR
Note the gains on this gragh below with no other changes except for one of my ported 90 units (same day on the same dyno)
Isn't this Patrick G's dyno sheet? I thought he also changed from a 75mm MAF to an 85mm MAF for that dyno test.
Old Aug 25, 2006 | 10:13 PM
  #62
sditch's Avatar
Tony,
Is this true that a TB was also changed? What were the mods on the car?
Old Aug 29, 2006 | 07:31 PM
  #63
Tony Mamo @ AFR's Avatar
Flow Wizard
Smokem...
You are correct and I apologize that I hadn't mentioned that....to be honest its been so long I completely forgot. That gragh came to mind purely because it was a perfect example of how a properly modified FAST can not only bring big peak gains to the table but also enhance the bottom of the curve where a stock unmodified FAST really falls short.
Also, to be fair, at the low 400 RWHP level, I would be surprised if the larger MAF was even worth 3 HP and the gains would purely be at the top of the curve. Even at close to 500 RWHP the larger MAF might only be worth 3-5 HP but if your going to the dyno anyway, for the dollars invested a larger MAF still certainly makes a lot of sense. Ive also seen threads where the gains from a larger MAF have almost been negligable (perhaps tune related).
Either way though I should have provided that info with the dyno gragh....
Tony M.
Old Sep 17, 2006 | 02:12 PM
  #64
j4nash's Avatar
what is the hp tq difference between the 78mm ls6 intake and the 78mm FAST intake?
Old Sep 17, 2006 | 02:59 PM
  #65
Flow Wizard
Slight loss of low RPM power (below 3500)....about an 8-12 gain upstairs starting from around 5500 all the way to redline (obviously tune and combination dependent). Add 3-5 HP for an unported 90 mm version (and larger TB obviously)....identical curve at the lower RPM's.
Tony M.
Old Sep 17, 2006 | 03:37 PM
  #66
AFRLS1's Avatar
interesting info
Old Sep 17, 2006 | 10:32 PM
  #67
OJmobileII's Avatar
for comparisons between:
Ported FAST 90/90
Ported LS2
will the particular set-up have a big effect on the gains? for some set-ups would one intake be better suited? or would the difference in set-ups jus be negligible?
Ported FAST Price = 3/2 Ported LS2 Price
it seems like many people r not disputing the FAST having better gains than the LS2, but they r wondering if the gains justify the overwhelming increase in price.
i feel like maybe on an aggressive set-up 500+whp the Ported FAST is well worth the xtra price, but maybe for the concervative setups 400whp the Ported LS2 would be dramitically better than the LS6 and almost as good as the Ported FAST. so for the price the Ported LS2 is a better option for those individuals.
Old Sep 18, 2006 | 12:56 AM
  #68
LS1FIRE's Avatar
What is needed to run the LS2 intake? Also what TB should be used? Is the LS2 Tb electronical?
Thanks
Old Sep 18, 2006 | 08:16 AM
  #69
VINCE's Avatar
Shorty Director
I would take the LS2 intake. The price is cheaper and low/midrange is better for a street car. If I were going all out racing then I would get the FAST..
Old Sep 18, 2006 | 12:58 PM
  #70
j4nash's Avatar
Tony M.
so the gain between a LS6 and a 78mm fast is very small. so for the money the LS6 is the way to go?
Old Sep 20, 2006 | 04:22 PM
  #71
j4nash's Avatar
anyone have some dyno numbers for, ls6 vs. 78mm FAST?
Old Sep 25, 2006 | 01:16 AM
  #72
Blown04Z06's Avatar
thanks to this thread, i contacted dave and picked up his DTP stage 2 cam and his ported fast 90, for way less than i thought it would be. dave my car should be done this friday, once it is ill send you the dyno results. i decided to get the LS2 tb ported by mark shanner from www.s2performance.net he lives 10 minutes from me, figured id give the ported fast its full potential.
the only down side is i ran out of money and im going to be reusing the stock exhaust system w/corsa cat back.
Old Sep 25, 2006 | 06:59 AM
  #73
Patrick G's Avatar
LS1 Tech Administrator
You'll have to do a search for 3 years ago when the 78mm FAST first came out. Most of the 78mm FAST setups gained little to no power over the LS6 intakes. It wasn't until the 90mm FAST came out that you started seeing BIG gains.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Sep 27, 2006 | 10:40 PM
  #74
Blown04Z06's Avatar
there is a magazine article GM high perfromance tech(?) where there is a comparison LS1/LS6/Fast78 then they added comp cams into the mix there really wasnt a difference between LS6 vs fast 78
Old Dec 4, 2006 | 07:49 PM
  #75
OJmobileII's Avatar
someone asked a question in the external section and it got me thinkin about this thread again. so i searched for it, found it, and now am bumping it after 2 months...
has anyone had a chance to do a true comparison test of ported LS2 vs ported FAST 90? same day, car, etc? i know Tony Mamo was talking about posting if he had a chance, but i havent seen it if he has.
i see LS2 intakes still going for less than LS6's and prices seem to be continuously dropping. this makes me think they are garbage and i should stop looking at them. but i still wonder how it compares to FAST (and y not an LS6 too) on a cam only or mild H/C car (something jus over 400whp)???
Old Dec 4, 2006 | 08:58 PM
  #76
Flow Wizard
I'm hitting the engine dyno in early January with a 403 I expect to make about 600 or so with one of my ported FAST pieces....if someone wants to loan me a ported LS2 I would be more than happy to swap it right on the dyno. I am going to swap a stock LS2 intake if I can get my hands on one....at least that was the plan and I think there is a good chance of that happening.
Tony M.
Old Dec 4, 2006 | 09:10 PM
  #77
bad95killer's Avatar
Tony M.
Hopefully someone give ya a hand in this then make a damn fair comparison but i still have a feeling that the ported FAST intake gonna slightly edged out the Ported LS2
Good luck Tony .
peace
Old Dec 4, 2006 | 09:33 PM
  #78
OJmobileII's Avatar
Good luck Tony .
peace
i have no doubt the ported FAST will edge out the ported LS2. i am concerned with by how much...
Old Dec 5, 2006 | 08:00 AM
  #79
Justin00SS's Avatar
Now I'm interested in this. lol
Where can I get an LS2 intake? haha
Does the LS2 intake use the stock LS1/6 fuel rails?
Old Dec 5, 2006 | 08:53 AM
  #80
OJmobileII's Avatar
different fuel rails and injectors. i'm sure u can modify it to accept ur existing rails.
