LS2 vs Fast 90 dyno comparison
So If the ls6 makes more hp than a ls2 intake and I gained 20 hp going to an unported fast intake how could a port job on a ls2 intake even be compaired to a ported fast intake.....?
I now have a ls2 in my gto and I really want to do something with the intake but Im just not sure what to do after reading this thread
I agree that a gutted, trumpeted, & port matched LS2 has not been explained completely. Here is an attempt. The bottom is cut out in a rectangular fashion (see pic), then the three internal towers that connect the base to the top are removed, then a very specific epoxy can be used to trumpet the inlet to the internal runners (yellowish in pics), then sand & smooth. On the runner outlet, confirm proper alignment to head inlet runners, sand down internal ridges, & sand smooth. Once all work is completed, the three holes that remain in the LS2's bottom from removing the towers are plugged, then use nylon compatible plastic welding rod to re-attatch the base. I went a step further & sealed the welds w/ high temp silicon after welding.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Hi, I was afraid that my post would lead to that question. It will be tuned in April sometime & I have plans to post the results after, including cam spec's.. As for now, I can only say that it netted me 12 lbs less in front end weight over the aluminum Weiand/Holley that I had been using. For sure, will post the dyno (Mustang) results once it has been tuned.
My car spends most of its' time "under the curve" & up to 6,400 RPM. For this reason & after seeing a few threads w/ LS2 trumpeted (AKA ported) results, felt that this was a good choice for me. Were my car a 7K rev vehicle, may have gone w/the FAST.
To the guys looking into this. There was a question regarding the fuel rail. Yes, a stock LS1/LS6 fuel rail can be used. The mounting legs need to be bent into position to match the LS2 intake mounting holes. Also, a Katech "O"-ring kit is need because the LS2 injector "O"-ring ports are slightly larger.
I think that the rip comes from the documented poor numbers shown on stock LS2 intakes. On their behalf, unless someone ownes one & can actually see the three huge internal towers, that OMI are a big part of the restriction, it's difficult to understand what the term "Ported LS2" actually means. "Ported" does not really describe what is being done.
Cool that you are able to remove the towers without removing the bottom. Do you do anything to trumpet the inlet to the internal runners. This is the part, IMO, that likely increases low end torque in a "Ported" LS2 intake. If you are able to trumpet the inlet to the internal runners, you are a magician & my hats off, because it has to be a PITA. If you are doing nothing to that area, then there is more to be gained. Regardless, the more of us whom document what is beng done & results (my bad, as I have not documented any results as of yet), the more respect the modified LS2 intakes will receive.
Do you have any dyno sheet onebadws6?
PM sent onebadws6 for a price quote!!!
or fusor???
just an ideal i have one and cant sale it to save my life i need high rpm power so i was looking for a professional products intake
Here's what is not mentioned in my post. After welding, Herculiner is poored over the entire bottom of the manifold. The Herculiner seals the welded area completely & adds additional strength. Also, while installing the manifold, a piece of high temperature resistant header blanket is used between the bottom of the manifold & the valley cover (engine) to keep more heat away from the intake manifold & because I wasn't sure about the engine temps against the Herculiner.
Herculiner will save you time & aggravation.
where can i buy a sheet of plastic to match this???
and how close is the tb to any accessories i wanna try to move it down just a little 1/2 inch at most if im chopping it up i might as well go all out
where to get???
price???
The intake is made from nylon & a sheet of nylon would need to be used if you are to move the bottom of the intake down. I have an electric water pump & the assembly just barely clears it. I don't remember how close the stock WP was, but, don't think there's a 1/2." You do realize that moving the bottom down does not also move the TB down? The TB is positioned by where that part of the intake ends up once the intake & head runners are meshed.
I don't remember the epoxy name, but, there's a thread in the external section that define's it. If you can't find, send Tony Mamo (I think that's his name), the AFR guy a PM. He uses it for mock up stuff. Do not use JB weld, it won't hold.
alrighty i need to see i think i might still use fusor though idk for sure yet
the reason i say move thr bottom down is if i just move the neck and not the bottom to ill be in the same mess having somethin blocking my airflow
"UPDATE"
Bottom of manifold came loose & created a vacuum leak. Vacuum pressure sucked the re-attatched bottom, including weld & enough of the Herculiner, to create a major leak. After looking for a reasonably priced LS6 intake to modify w/ 90mm neck & almost re-installing my aluminum Weiand, I settled down a bit & decided to fix the LS2 bottom attachment issue once & hopefully for all.
This time, I bolted a phenolic plate that is wider than the cut out section of the LS2 intake to the piece removed from the LS2 intake, (invision a rectangular plate on top of a larger rectangular plate about 1/4" around the perimiter). The two plate assembly was then laid on top of the manifold opening w/ the smaller (intake piece) back in its' re-attatched location. The outer plate is larger than the opening in the manifold & bolted to the smaller manifold piece. Therefore, there is no way that the manifold piece can be sucked loose & into the manifold. The larger plate was then bolted to the intake for good measure. Finally, the whole added assembly was drenched in Herculiner. This includes, the saw cracks between the manifold removed palte & the manifold, between the bolted plates, & on top of the bottom of the manifold assembly. Will update again should an issue arrise.
As to my April yearly dyno session; have decided to spend the dyno funds on EFLive & have begun learning how to tune. Unfortuneately, this means that there won't be a dyno result of the mod. However, if I run across a dyno day or demo somewhere, will post up the results.
