Most power from a 370??
heads that flow 310 cfm @ .600 lift
custom FMS 24x/24x cam .6xx lift on 114 lsa
QTP 1 7/8 race high merge collector headers
QTP ORY turn down
stock crank, rods, pistons, seals,
LS6 intake
12 bolt
3.73 gears
3800 stall
Katech LS6 ported oil pump
255 LPH intank fuel pump
30# injectors
built 4L60E
i am not shooting for a record, just want to know what kind of power I will be making.
QTP ORY turn down
LS6 intake
12 bolt
3.73 gears
3800 stall
30# injectors
built 4L60E
Your intake will cost you around 25hp at that level over a ported Fast, so you should hit 470s with a really good tuner.
EDIT: just noticed 4l60, so you SHOULD be around 450-460 if you have a 9inch/12bolt.
