Strong AFR 205 Dyno #'s (and a beautiful C5)
Someone just turned me on to these results recently and I thought I would pass it along. Congrats to the owner and the boys over at LG.
http://forums.corvetteforum.com/show...6&page=1&pp=20
Originally Posted by dug
I wonder how much the 6lb flywheel helped.
Either way this car would be a very high 400 RWHP car thru 3.90 gears which is still impressive in my book.
Tony M.
Originally Posted by Tony Mamo @ AFR
I'm thinking 16 pounds, but I'm sure it helped a little bit (more assuming it's actually 6 lbs.). Not sure if a full size wheel could even weigh that little. Don't have the time myself right now but maybe someone else could research that number.
Tony M.
Tony M.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
What compression ratio does it have?
1 Post
He did it with no belts on the car, what does that give you 10RWHP or more?
Freakin' impressive #'s, and the paint job is one of the best I have seen...did you see the painted the FRC's too?
Guys,
Heads were 205's "out of the box"....
Knowing Lou they were his typical 205's milled to 59 cc's....then you have to add for valve reliefs. etc.
(11.4-11.5 more than likely)
I'm sure Lou will correct me if I'm wrong
BTW, Lou stated on a different forum that this car put down 494 with the full exhaust and the belts hooked up. With stock gearing this car would have cracked 500 RWHP in total "street trim".
Thanks,
Tony
Thanks,
Tony
1 Post
Guys,
Thanks,
Tony
Thanks,
Tony
I had a feeling he would get around 10 RWHP for the belt. Still a very impressive car. Gotta luv those AFR heads...the performance speaks for itself.
