HORRIBLE F13 only dyno #'s. PLEASE HELP
!LS1 11 Second Club
Originally Posted by TroubledWine3
What's wrong with SLP headers, performance-wise? Sure they don't fit that well and they give you bad clearance but I was unaware that they had a flow problem.
Thanks guys! SouthFL, I am OK with my combo and am aware there are better LT's out there, but my wife mainly drives the car and it's raced on occasion(not that much) although I appreciate your help, I just want to make sure the current combo is making ALL it can!
I am not TOO versed on tuning so Im stuck with trying to figure it out myself or pay for a dynotune and still have PT to tune.
AARRGGHHHHH!!!
AARRGGHHHHH!!!
Well, did some work on it tonight. Turned around teh set screw on teh TB so that I can adjust the idle a little and help with the surging, replaced my O2, and pulled a couple plugs. Here they are
Pretty fouled. I believe the stock tune was soo out of whack it fouled out my plugs over the course of driving it before. Now I gotta get this Part throttle stuff down!!!
Anyone wanna help with that??
Chris
Chris
Damian See above^^^^^^
I think that is part of it! I did just realize all the ones I pulled were fro the drivers side(side that had the bad O2 I just replaced) So I'm not sure if all 8 are like that or only the drivers side. I will pull some from the passenger side and report tomorrow!
Thanks
Chris
Thanks
Chris
Hey I am looking through your dyno-pull...
-I noticed your injectors are showing 80% duty at 4650rpm and hit 100% at 6000rpm, just an FYI...
-Your are locking a positive LTFT of 12 at WOT. When you hit WOT your last postive LTFT transitioned through will be added to your PE value (as a percentage).
-Looking at all your LTFTs it appears you car is running lean (8-14%) and the PCM is playing catch-up to add fuel.
-Your timing starts off at 29.5 and drops to 23 (4700rpm) and then goes back up to 27.5 (5500rpm). Did you have to do the 23* to stay out of KR???
Other than the timing being a little low in the mid-rpms and injectors being MAXED I am not sure where your missing HP is. I am going through your current tune right now... None of the above should amount to much...
Im not sure. I have not messed with the spark advance. Yeah and on the dyno it was lean also, but Im not making enough power to max the stock injectors! I replaced the bad O2 last night(drivers side) and will do a street pull tonight and see what you can make of it. Thanks for all the info. VERY helpful!!!!
#32
#33
Originally Posted by LTLHOMER
Prolly why the plugs look the way they do...too much fuel. That would make a motor seem pretty lazy, but that doesn't agree with your a/f readings (are you sure they were high 13's and not high 10's?)
I will get the dyno graph today! Thanks! The new file was much better than the old one with the new O2, and fixing the intake tube, and cleaning the plugs.
