TR220, two dynos, two tunes
Old Dec 24, 2006 | 05:57 PM
rktsled's Avatar
Looks like his afr still could be better. I wouldn't go past 13.2 afr scares me. 12.8 you will get better torque # 12.2 is best for hp
Old Dec 24, 2006 | 06:02 PM
Slowhawk's Avatar
LS1Tech Sponsor
Timing and A/F work together. You can run 14-1 A/F with the correct timing for it.Optimal 12.8-1 is a myth.
Old Dec 24, 2006 | 06:17 PM
rktsled's Avatar
Thats just what works best with my car. I'm at 26 degrees timing with a 12.8 afr If I try to change it the car loses power. I would add more fuel if it was me and then add timing if need. But ever car is different. I would just try it and see if it would add a few hp.
Old Dec 24, 2006 | 09:18 PM
Slowhawk's Avatar
LS1Tech Sponsor
Here is the question. Is your car the fastest at 26 degree's timing and 12.8 A/F ? It may make the best Dyno hp but does it run the fastest at that?
Just making a point.I thought the highest dyno hp would be the fastest until we spent a ton of time at the track. The results were very surprising.
Old Dec 25, 2006 | 01:32 AM
rktsled's Avatar
I can't tell you that. because I haven't had it to the track after the tune. was tuned 3 week ago. We Just got the car running right. I already got your point. I had it really close but had 6 degrees to much timing. I even backed it of to about 24 degrees and ran like a dog. I don't go to the track but once a month. All i know is my low track light has never come on and stayed on though 3 gears and after the tune it does. I was just trying to help the guy out is all. Not to have someone that knows it all jump my case.
Old Dec 25, 2006 | 05:43 AM
Slowhawk's Avatar
LS1Tech Sponsor
LOL,Not jumping your case. I did go alittle off track though to make a point that A/F is different for every car
Sorry for the hijack.All that matter's is that the car is running good
Old Dec 25, 2006 | 03:41 PM
rktsled's Avatar
No hard feelings here.
Old Dec 26, 2006 | 12:19 PM
Felix C's Avatar
Hello,
Nice numbers. A few questions if you do not mind.
1. Is this the 112 or 114 LSA cam?
2. Is it installed with 4deg advance?
3. Should it not make power above 6000rpm?
4. Is there noticeable lope at ideal?(what rpm idle 800?)
Old Dec 26, 2006 | 09:07 PM
fasteddyss's Avatar
Well the power of search has resurrected this old thread of mine I see.
The main thing I learned and wanted to share my experience about was exactly what slowhawk noted:
Looks like you learned a lesson about tuner's. Showing that the "dyno" #'s are pretty much the same but you feel the difference in the tune. The first shop didn't know how to tune idle,midrange,throttle response and could only do WOT timing/A/f. The second shop did the tune correct which is why the car feels so much better. I'm expecting that the 220 Cam idle's/drives pretty much like a stock car except a big improvement in throttle response and power
That pretty much sums it up. The difference in idle quality, driveability and feel of power was night and day between the two tunes.
The specs are 220/220 551/551 on a 112 LSA. I wanted the 112 LSA cam to keep my low end grunt, and it has delivered that. I installed it straight up with no advance.
There is a noticeable lope at idle, but only to people who know about such things. Your wife, grandma or dentist will never notice. It idles at stock rpm 750?, it is stored for winter right now or I would check.
The cam peaked at about 5800. I believe this is typical for a cam with similar specs.
All in all this has been a good street cam for me. I would not go much bigger in a daily driver myself, although many have. I have put over 20k on the car with this setup and have been pleased.
Old Dec 26, 2006 | 09:53 PM
Mazzenger's Avatar
the hitech graph is almost identical to my old T1 221/221 one cam from a long ago.
Old Dec 27, 2006 | 04:00 AM
dynocar's Avatar
The first dyno may not have used SAE correction. If true, you cannot compare numbers if improperly operated, even on the same dyno two days apart. It appears that tne second dyno did. The close numbers between the two dynos could be coincidental.
On dynos that you cannot simulate actual load to an engine, you can tune more lean with more ign timing advance. However, when you take it to the track you may have to retune for optimum performance. We have often demonstrated that on our dyno by turning the load control off to simulate an inertia dyno, tuning the vehicle for that ragged edge, then turning on the vehicle simulation load and watching the power decrease dramatically due to knock retard, etc. Good DJ operators are aware of this and try to compensate after getting good numbers.
Old Dec 27, 2006 | 06:49 AM
  #32
vettenuts's Avatar
I am just surprised that it was DRM that didn't do the tune correctly.
