Check these stock numbers out
The car made 363 RWHP SAE, 370 RWTQ SAE. It would have been higher but the car went lean (15.2) from 4,800-5,800 and then came back down to 13.1 at 5,900 thru 6,200 where I told him to stop. There is something amiss in the fuel map but I'll remedy that when I dyno it again (HP Tuners) after the H/C install this weekend. From the look of the graph there would have been at least another 10-15 RWHP had it not dipped from the lean mixture.
The only mods are:
FAST 90/90
Edelbrock Stepped LT's/ Y-pipe
85mm MAF
85mm TSP lid
ASP pulley
4" Mufflex catback
160 T-stat
K&N
Those numbers are through a 6speed and a 12 bolt. Not to mention the motor has 92k on the clock.
The dyno sheet is posted below a few posts down.
True. I just meant stock internals. I had just never seen a bolt on car around here that did that much all things considered that I mentioned above(lean, 12 bolt, 92k).
Thanks!
Jeff
Are ya running 3.73's or higher ratio ?!
post the Graph if it's possible
peace
Thanks,
The car has 4.10 gears. I need to figure out how to post the graph, but I'll give it a shot today.
Jeff
Yeah not sure what the deal is on that. I'm putting my big pump in and changing the fuel injectors out just to cover that. I may have had an intake leak as well from what I saw when I pulled the motor last weekend. We found oil on top of the valley cover but I dont think it was coming from the valley cover itself.
But if it is coming from a leaking intake runner gasket(where it mates to the cylinder) that is strange also b/c I have an AMW catch can and I would think it would catch almost all oil vapors to keep them from entering the intake.
Jeff
