RWHP differences with a 12bolt
Old Feb 1, 2006 | 11:56 AM
FRDnemesis's Avatar
Default RWHP differences with a 12bolt
I did a search and didn't find anything, so I'm gonna take a chance and ask.
Has anyone seen or tested the difference in RWHP numbers between a 10 and a 12 bolt? More specifically with a Posi instead of a spool but either way is fine.
Thanks,
Jeff
Old Feb 1, 2006 | 12:11 PM
bad95killer's Avatar
Actually with same ratio (10bolt with 3.42 vs. 12bolt with 3.42) ya might see 5-10 rwhp off .
peace
Old Feb 1, 2006 | 03:44 PM
SuperZ's Avatar
Im not so sure it would be as high as 10rwhp.I would say 5rwhp on same ratio gear.
Old Feb 1, 2006 | 08:32 PM
TINKRD's Avatar
i didnt lose any HP between my 10bolt and 12bolt, but i did lose ~23ft/lbs of TQ.
I wish I still had the dyno graphs. :think:
Old Feb 1, 2006 | 09:49 PM
02 Camaro SS's Avatar
I've heard 10-20rwhp is not uncommon when changing and upping the gear ratio.
Old Feb 2, 2006 | 07:58 AM
FRDnemesis's Avatar
Wow, I would have thought more but then again, thats why I asked.
Thanks guys!!!
Jeff
Old Feb 2, 2006 | 10:43 PM
ChaseSS's Avatar
how does a gear change differ the rwhp? higher gears = more power or opposite
Old Feb 3, 2006 | 08:14 AM
jimbob's Avatar
More Friction=less power....However, there's always a however!....on a Stalled Auto you might see more power on the dyno as a result of less slip in the verter in the higher rpm's (with higher gears).
12 RWHP loss from SAE tuned car with 3.73's in 10 bolt, to 12 bolt Strange with 3.73's, direct before and after. Both me and Ed Wright loose the same with the rear end changes....
