'01 camaro h/c dyno numbers
Old Feb 10, 2006 | 05:24 PM
blubird's Avatar
Default '01 camaro h/c dyno numbers
Had my first go at dyno tuning today. The numbers were put down on a mustang dyno.
uncorr. sae(.96 CF)
rwhp-420 403
rwtq-373 358
The first pull was 402/361(uncorr). Peak hp came in at 6600 and carried all the way to 7000 where it dropped like 3-4 hp. Peak torque was at about 4800. I'm pretty happy with the after tune results. The car picked up 22-25 hp in some areas between 5000-6000 rpm.
The big ticket mods are TEA stg II 5.3s(4 yr old version),232/236 cam,fast 90/90. This was also through mac mids and borla catback, and the car has a 9" with 4.57s. No short belt or EWP which are to come shortly.
I hope to get some track numbers next weekend.
Old Feb 13, 2006 | 10:52 PM
camarokid94's Avatar
good times, awesome number. should feel fun. congrats
Old Feb 13, 2006 | 11:26 PM
lilbuddy1587's Avatar
Get some longtubes and a cut out dude. Dont skimp on the goods
Old Feb 14, 2006 | 05:01 AM
blubird's Avatar
I have some 1 3/4-1 7/8 headers with HVMCs, but they were for a different project that I will not be using them for anymore. I just haven't decided if I want to change them out or not.
Old Feb 14, 2006 | 07:13 PM
JaSSon's Avatar
Did you flycut?
Old Feb 14, 2006 | 07:28 PM
blubird's Avatar
Originally Posted by JaSSoN
Did you flycut?
I did not have to flycut. I have plenty of PTV clearance.
Old Feb 15, 2006 | 04:30 PM
black01_WS6's Avatar
is this a auto or m6? if auto the numbers seem low with your set up. mustang or dynojet? good tq.
Old Feb 15, 2006 | 04:54 PM
algws6's Avatar
i used to have those same heads, they rock. i ran an 11.7 @ 117 with a G5x2 and those heads with a 4500' DA.
Old Feb 15, 2006 | 05:31 PM
blubird's Avatar
It's an m6. Previous owner ran an 11.15@124.7 in it, but that was with a ls6 intake and TR230 cam. I have ran a 7.16@98.3 1/8 w/ same set up. I'm hoping for some 10's out of it, but we'll see. Race weight is about 3400lbs.
Old Feb 15, 2006 | 05:32 PM
blubird's Avatar
That's a great mph for that DA.
Old Feb 15, 2006 | 09:23 PM
JaSSon's Avatar
If you dont mind what the specs on your cam. LSA and ICL please. How much advance in it?
Old Feb 16, 2006 | 05:00 AM
blubird's Avatar
LSA-113; ICL-113. The cam is installed straight up. I would have installed it on a 111 or 110 ICL but it was recommended to me to install it straight up due to PTV. I had > .08 PTV but I'm not sure how much that would change if I retarded the cam.
Old Feb 16, 2006 | 10:44 AM
JaSSon's Avatar
So there no advance ground in it? What kind of lift? Im interested in running a bigger cam and dont want to flycut.
Old Feb 16, 2006 | 10:57 AM
UnbelievabLS1's Avatar
In my old SS, I ran a similar set-up. The heads were the ones in the sig, as was the cam, but the cam was on a 108 ICL, and it was a 110 LSA. The lift was .579 on both sides. My heads were milled .030", and I had to flycut. With all the mods in the sig, it did 464 rwhp and 419 rwtq. Def. throw the stepped headers on there, as well as a cutout, and your numbers will take a jump.
Old Feb 16, 2006 | 02:18 PM
smokemup's Avatar
Nice times, corrected to sea level it's 11.051 @ 123.915 mph
Old Feb 16, 2006 | 09:45 PM
blubird's Avatar
The lift is .579 on both sides. The duration of the cam will affect the PTV more than lift. Due to the aggressiveness of the lobes the lsa/icl was selected to increase PTV.
Old Feb 18, 2006 | 09:19 AM
You must have bought that cam through TEA, because I was the one that came up with it back in Feb. 04'. It uses Comp's Renegade lobes, and yes they are pretty aggressive.
Old Feb 19, 2006 | 12:27 AM
blubird's Avatar
You are correct sir. Unfortunately I can't take full advantage of it since I didn't want to flycut my pistons.
