Dyno Depression what gives (low dyno numbers)
Well yesterday I got my car chasis dyno'd. I have to admit I thought the number swould be a bit higher what gives? I put down 292.9rwhp and 320tq Am I just expecting to much or not? My engine mods are .........
Flowtech Long Tube Headers & Dumped True Dual Exhaust
2.5" x-pipe, 2-24" Sweet Thunder Chambered mufflers
Whisper Lid / K&N Filter / Smooth Bellows
Hypertech PPIII & 160 thermo
NGK tr55 plugs & Taylor 8mm Plug Wires
114,000 miles on motor as well THX
Well, if it was a mustang dyno it will give lower #s than a dynojet, and A4s dyno less than M6s. Your 114,000 miles probably played a factor as welll. And maybe it hasn't had a plug and wire change in awhile?? That might help. Maybe your car can really benefit from a dynotune.
Theres a lot of possibilities, but those numbers do seem pretty low.
Originally Posted by cantdrv65
....It usually results in knock retard.
Anyways, A4's always dyno less and if that was a mustang dyno you shouldn't worry in the least.
Originally Posted by slimcracka
dynos are tuning devices..and a4 are no dyno queens..track time will tell you more was the converter locked? and is it a stock stall?
Mine dyno'd 300whp and 312wtq (on a dynojet w/110k miles, the guy shutdown at 5200rpms though), mods in sig, and that's with an unlocked 3800 stall. I've heard those HPIII tunes are junk, keep it to have the fans set for your thermo and change the shift points rev limiter if you like, but take out the tune it does. Auto's are no dyno queens as everyone said, but with your mods you should definately be higher than that.
Other than that, never heard of that kind of dyno, what was your a/f?
Numbers in sig, my car wasn't tuned till after it hit the dyno. My car was running 17.1 A/F, blew the motor at anytime. I know that you have a handheld but the dyno tune will blow your mind not your motor. Its worth looking into.
No a/f because the guy counldn't hook up the equipment with my dumped exhaust. He said it would be too close to the rear tire. It did puff black smoke when he got off the gas and it reaked like gas.
do you have any trap speeds to contribute, uno? that will tell you how accurate that particular dyno is. i wouldn't worry about the mileage affecting your car's performance. my buddy is on his second ls1 with 130k+ on it. this car is VERY strong. my point: don't let the mileage scare you. it seems to me that you have a tuning issue and an overly conservative dyno.
My numbers are actually low because we figure the lean condition was putting the car into the low octane tables. I had a hpp3 tune on the first two pulls. I removed it on the 3rd and nothing changed. The tune was probably not in effect because of my lean condition. Once again, you need an A/Fr to get a good idea of what adjustments need to be made.
I agree with 01 about the A/F ratio. There has to be a way to get it hooked up and then hook your car up. I would imagne (a total guess based on your setup) you could gain from a dyno tune and setting the right A/F ratio you could gain some serious HP improvement (20+) and some pretty nice torque (15+). Again just my opinion and your car is not in front of me.
I think I am going to purchace a VINCI handheld tuner. Seems that would work best for me. I am going to head back to the dyno after I get my LS6 ntake and ported Tb. Thx for all the insight guys.
Originally Posted by Louie83
He just asked a question, no need for name calling. .
On point, So you didnt use any tuning software while dynoing other than the having the HPP3 program uploaded on ur pcm??? All you did was just make some pulls???
I agree w/ the others as to you running rich w/ the black smoke
