Turbo Formy Dyno Sheet
stock bottem end with 6l heads and a turbo at 10psi
the black one is the last run we made. it was overlaid with the previous pull. we added some timing earlier in the rpm range. made it look a lot better. 18 total degrees of timing.
hope that pic shows up
btw, will i have balance problem of the rotating assemblly with only change being the custom pistons?
thanks for the info.
