TR230/224 A4 Dyno
Old 04-24-2006, 10:31 PM
  #41
Zick's Avatar
Very nice
Are you running stock heads?
Old 04-25-2006, 08:08 AM
  #42
gillbot's Avatar
Heads have never been touched or off the car!
Old 04-26-2006, 01:58 AM
  #43
hammertime's Avatar
Great numbers for a stalled auto with stock heads.
Just curious, what led you to choose this cam? A lot of people are set against the reverse split...
Let us know if you get some new track #'s - but I guess that would be tough since you were 12.00 last time out.
Old 04-26-2006, 07:21 AM
  #44
gillbot's Avatar
I've had this cam in the car for quite some time. It was recommended by a local guy and I decided to give it a shot.
I plan on hitting the track again at T-n-T but it's notoriously crowded and poorly prepped so we'll see how the times go. 11's should be there easily if I can get the car to hook. Worn out nittos and poor track prep aren't good for low 60's.
Old 06-16-2006, 09:03 PM
  #45
gillbot's Avatar
Video of my 11 sec passes:
http://www.dayton-fbody.com/misc/dra...06/JMG1185.mpg
http://www.dayton-fbody.com/misc/dra...06/JMG1186.mpg
Old 07-02-2006, 11:15 AM
  #46
Dave D's Avatar
So was that with the SLP MAF back in the car? I have an SLP also and am concerned at your post about it not being a good product. What do you think??
Old 07-02-2006, 12:39 PM
  #47
Sport Side's Avatar
Gillbot,
I like the shape of your torque curve. No dips, just a steady increase and then FLAT.
I was wondering... Was this cam installed 'straight up' or 'as is' at a 111* ICL (0* of advance)? There are two Hi-Tech motorsport's cams out there that I recal, both being reverse splits with 2* of advance set to them, with very similar torque curves.... That large slope that forms into a very flat curve.
On those 11 sec passes, what kind of 60' times are you pulling and what tire are you using?
Lastly, I'd like to see what a good set of long tubes would do to your torque curve.
Thanks for your time!
Old 07-02-2006, 04:05 PM
  #48
gillbot's Avatar
Yes, this was with the SLP MAF. We had a hard time getting it tuned on the top end because the maf would "stall out" and not count any higher as the RPM went up. We weren't sure if it was a MAF issue or if the engine was just consuming all the air it possible could and something else was restricting it. Seems to run good though so we left it. I've been told that removing the resistor and running the Z06 or Truck MAF table would be better so I may try that at a later date and see if that helps.
Originally Posted by Sport Side
Gillbot,
Cam was installed dot to to, no advance. My 60' on the 11.85 pass was 1.6692 using MT Drag Radials. I've thought about pulling the MAC headers and running a set of LT's but I don't like they way most of the Y pipes fit and i'd hate to lose any more ground clearance. I scrape enough as it sits now.
Old 07-05-2006, 11:55 AM
  #49
steveo346's Avatar
Nice Numbers Buddy......
Old 07-05-2006, 12:38 PM
  #50
you2slo's Avatar
I wondered how your times kept dropping. Awesome numbers!
Old 07-05-2006, 06:20 PM
  #51
gillbot's Avatar
Thanks!
Old 07-07-2006, 10:38 AM
  #52
steveo346's Avatar
I Hate You Gillbot
J/K
Old 07-07-2006, 10:44 AM
  #53
sac
sac's Avatar
any suspension or weight reduction and any other mods?Sweet car man!
Old 07-07-2006, 02:59 PM
  #54
gillbot's Avatar
All mods are here: http://dayton-fbody.com/DFBAbb/viewtopic.php?t=1407
only weight reduction is rear seat, spare tire and jack removal.
Old 07-09-2006, 08:51 PM
  #55
'Trust''s Avatar
Holy crap. Nice numbers, I'm not even there and I have some touched up 241's, baby cam on mine though! Nice work!
Old 07-10-2006, 05:37 PM
  #56
gillbot's Avatar
All it takes is time and money!
I found that if you just open your wallet at the intake and let it suck as much as it wants, you are set!
Old 08-01-2006, 03:39 PM
  #57
steveo346's Avatar
Hey Gillbot I Hit 390hp And 380tq
Old 08-01-2006, 04:54 PM
  #58
gillbot's Avatar
NICE! Those M6 cars really have a leg up on us Auto guys on the Dyno for sure!
Old 08-01-2006, 05:53 PM
  #59
steveo346's Avatar
well yeah but...umm well yeah....the weather was 104 degrees outside when i dynoed on sunday....i was sweating my nads off!!!
Old 08-01-2006, 06:30 PM
  #60
gillbot's Avatar
That's what I meant, you hit 390 in sweltering heat!
(I saw you were from TX)
Quick Reply: TR230/224 A4 Dyno
