Question for the 500+ rwhp Big Dogs
4.10's, numbers in sig, 275 bfgoodrich g-force T/A drag radials, every suspension mod there is and on the spray my tires dead hook everytime rolling into the gas in first and barely even chirp the tires on shifts. Its all about tires and suspension.
The RA-1s will leave the nittos in the dust on a road course. Keep them unless you are going to a Full slick Good year.
Traction should not be an issue and you should have no problem in my opinion. The added torque will make the car much more fun. 1st gear is not used at all on either of those tracks.
Now the street? Thats a different issue....
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
LS1TECH Sponsor
ok my vette put down 550 rwhp 501 rwtq, i run Nitto R2 road race tire, basically there drag radial with a stiff sidewall, i can pretty much hook in first gear until the power starts coming on hard around 4000 rpm, then they light up(this depends on that it at least around 70 degrees out side), but i can at least hook from 2nd gear on, they are an awesome tire. but with BFG kd's i would spin through third gear all day.
Now the street? Thats a different issue....![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I'm the guy you drove around with in Russ Oasis's Viper at Willow a month or so ago. Don't know how happy it makes me that you participate in the forums. I'm ditching the 346 to go with a 402, keeping the LG LT's of course!
I also got rid of the 19/20 combo and the car hooks much much better with the RA1's and 18 inchers.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Originally Posted by Pio
Those are the numbers I'm looking / hoping for. I'm just going to have to modulate the throttle in 1st... How do the guys that have blown strokers with 700 plus to the wheels do it? ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
