382ci dyno #s - 505rwhp/478rwtq
I can shift faster than you.
I finally got around to rebuilding the motor in the black car (2000 black WS6). After 135k miles, it was burning a TON of oil. Since it was out of the car, why not put some nice pistons, rods, and crank in?? Always upgrade.. never replace!
Specs on the new motor:
- LS1 block
- Mahle -6cc 3.905" pistons
- Mahle rings (1.5/1.5/3mm, std tension)
- Eagle LS1 specific 6.125" connecting rods (ARP 2000 bolts)
- King rod and main bearings; Durabond cam bearings
- Callies 4.00" crankshaft
- PRC stage 2.5 5.3l heads (2.04/1.57 valves)
* coated Comp 921 valvesprings
- Thunder Racing 7.350" pushrods
- Thunder Racing 235/248 .653/.618 112lsa (110* intake centerline)
- ARP head and main studs
- Melling high-volume oil pump (ported)
- Comp adjustable timing set
- Comp OEM replacement lifters
Mods on the rest of the car:
- Whisper lid
- LS6 85mm MAF
- Thunder Racing 1 3/4" headers
- Mufflex 3" y-pipe
- ASP pulley
- Hooker catback
- FAST 90mm intake (ported)
- Nick Williams 90mm throttle body
- Delphi 37lb injectors
- Racetronix 255lph fuel pump w/ voltage booster
- GM Motive 4:10s, stock rear
- Spec stage 3 clutch, steel flywheel
- Full road race suspension (Koni shocks, Suspension Techniques springs, BMR LCA, PHR, 1LE sway bars,etc...)
The car put down 505rwhp/478rwtq with the cutout open. The car needs a ton of tuning (A/F was 14:0:1), so I think it will make an easy 515+ is possible after the tune is done. I was very pleased with the setup considering how mild the cam is (at least in this size motor)! You can really feel the extra torque on the street over a 346ci setup!
Here is a TON of pics of the motor assembly and install:
http://www.thunderracing.com/users/jason/382buildup
BTW, stock rear, 4:10s and this kind of power = KABOOM!! I'll post some pics later of the damage! They didn't even last one evening with the new motor. I put some new 4:10s in on Sunday night (midnight) so I could make class at 8:30am!
Geoff@Thunder has his new emulator which makes tuning driveability, idle,etc. much easier! It is really cool to see changes happen in real-time and not having to re-flash the computer everytime a change is made.
So, finally, I have my car back on the road again!
While I had the motor out, I had Allan@FMS go through my T56. It shifts awesome now. It's like I have a whole new car with the new motor, new tranny, and new gears!
HUGE thanks to everyone who helped along the way - Natalie, John, Jonathan, etc... the car wouldn't be on the road without them!
Jason
- LS1 block
- Whisper lid
- LS6 85mm MAF
- Mufflex 3" y-pipe
- ASP pulley
- Hooker catback
Jason
Glad to be the first one to Congrat ya Jason
This kind of power definitely put ya in 408's high CR N/A territory & considering the A/F ratio there's much more power for that stock rearend to handle hah
if ya have the time post the graph , oh just a few things to ask how much the heads milled & what is the CR ?!
looking forward for track #'s man..good luck !!
peace
peace
LS1 Tech Administrator
Badass Jason. That's some tremendous power for such a streetable package. You've got 427 power at a 383 price! Can't wait to get a ride!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by Jason99T/A
Thanks man! I hope your setup is going together well too!
Congrats on the numbers. I'm not trying to steal your thread but I keep seeing great numbers from these type setups. I find these setups more appealing than a 408 setup but the cost is almost the same, why? The cranks I find for a setup like this are so damn expensive. Do they make a budget 4 inch crank?
I went with the 382 because I didn't want to add the ~100lbs to the front of my car with the iron block. Plus, I have built a ton of LS1 based motors for the past 6 years, but only 1 other 382. I just really wanted to try something different and see what I could get out of it.
Congrats!!
I'm also curious as to why you had to use 7.350" pushrods. was it due to milling a certain amount off of the heads, if so how much did you take off.
