Dart 205 dyno numbers are in!!!
Old Apr 1, 2006 | 12:11 PM
VINCE's Avatar
Shorty Director
Originally Posted by Patrick G
Thanks for the clarification. Again, damn fine numbers!
Oh I see how it is.. You did not believe me?
Old Apr 1, 2006 | 12:48 PM
Futral's Avatar
The dyno software prints the graph out of place. It was fixed for a while when Dynojet updated the software but had other glitches in it so I went beck to the older version.
If its a big deal to everybody I can e-mail the graph to Mark so he can repost
Old Apr 1, 2006 | 12:58 PM
vettenuts's Avatar
The last graph posted, for clarification, is the pre and post install of the Dart heads only?
Old Apr 1, 2006 | 01:32 PM
Patrick G's Avatar
LS1 Tech Administrator
I believe everything you say Vince, I guess I just didn't understand what you were saying. To me it sounded like you were saying the printed numbers were one thing (SAE or Actual) and the graph was something else (SAE or Actual). Sounds like I totally misunderstood. I didn't realize that the graph was neither Actual, nor SAE, but a lowered version of SAE. It's all good man!
Old Apr 1, 2006 | 05:57 PM
VINCE's Avatar
Shorty Director
I was just busting your *****, but I should have said SAE..
Old Apr 1, 2006 | 07:26 PM
Sigforty's Avatar
The last graph posted was the gains to get me where I was before the heads. The last graph was to show where the car was after the cam install. If you look at the baseline in the first graph it is 423 rwhp 405 rwtq, the second graph ends at 423 rwhp 408 rwtq. I was just showing that the graph axis was off on the first one and the numbers were correct though. The air fuel was around 13:1 I believe.
Old Apr 2, 2006 | 08:42 PM
gnx7's Avatar
Great numbers.... what cc are the chambers and what head gasket are you running? What compression do you think it is?
Old Apr 2, 2006 | 11:20 PM
Beast96Z's Avatar
Looks like these Dart heads are performing better as-cast than CNC-ported.
That's because DART's CNC program isn't out yet. Others vendors are using their CNC program and running it through the DART casting. Just like TEA does with AFR's. Results should only be better when the DART cnc program starts running. I highly doubt they'd release a more expensive option that produces less results.
Old Apr 3, 2006 | 03:03 PM
Malihoochie's Avatar
Beast96Z - well said! And our thoughts as well.
Old Apr 3, 2006 | 06:53 PM
Jason99T/A's Avatar
I can shift faster than you.
Nice #s Mark!
Jason
Old Apr 4, 2006 | 03:33 PM
Futral's Avatar
The heads are 61cc's with MLS .054 factory gaskets. The compression is about 11.0 cr.
Old Apr 4, 2006 | 03:49 PM
  #32
vettenuts's Avatar
Well I guess if PV isn't and issue with this installation, it won't be with my little 216/224 .581 .581 115 LSA cam.
Old Apr 4, 2006 | 07:12 PM
  #33
Futral's Avatar
No, you shouldn't have any problems with that cam! Looks like the Dart heads might have a little more free drop anyway.
Old Apr 4, 2006 | 07:44 PM
  #34
Scalpel's Avatar
How much are these Darts?
Old Apr 5, 2006 | 04:07 PM
  #35
Sigforty's Avatar
There are around $700 a head.
Old Apr 5, 2006 | 06:51 PM
  #36
Scalpel's Avatar
Assembled, i.e. valves and springs, etc?
Old Apr 5, 2006 | 07:12 PM
  #37
'hoochie2's Avatar
Give Futral or another sponsor a call & see what the going rate is. They are making x-cellent HP & TQ according to all the feedback, especially for the price.
Old Apr 5, 2006 | 07:25 PM
  #38
'hoochie2's Avatar
Those outta the box heads basically made 25hp/25tq gain on a car that already had a host of bolt ons AND a hot dyno-tune. Seems like $$$ well spent - especially if you consider what the gains could be on a bone stock car. After add ons are in place it is harder to gain efficiency because (hopefully) the add ons already made the motor more efficient.
Old Apr 6, 2006 | 06:32 PM
  #39
Ksett's Avatar
Not sure if all that makes a difference in the equation. Almost all before and after head comparisons have a tune on a cam only car with full bolt ons. The main point here is that he made 27 rwhp over an LS6 head, meaning if you have an LS1 headed cam only car you could assume at least a 37 rwhp gain if everything else were similar.
Old Apr 6, 2006 | 08:03 PM
  #40
waterbug1999's Avatar
Not unless I missed it, but did you have to notch the pistons?
