Dart 205 dyno numbers are in!!!
Old Apr 6, 2006 | 08:25 PM
  #41
ThirdGenLS1's Avatar
no he didnt have too
Old Apr 6, 2006 | 08:55 PM
  #42
waterbug1999's Avatar
I dont want, nor mean to steal this thread, but I purchased Stage II Darts (which I was told was a 62cc) along with the G5X3 cam. And well, I was told to use .030" (to get 11.1 CR) gasket and flycut. But, if he can use unmilled Darts with that cam and stock gaskets to get 11.1 (which is where I would like to be) then shouldnt I just get stock gaskets as well? From my numbers, I get 11.65.1. CR.. WTF
Old Apr 7, 2006 | 05:40 AM
  #43
Sigforty's Avatar
Originally Posted by waterbug1999
Not unless I missed it, but did you have to notch the pistons?
No notching here just bolted them on. Now the F15 cam has around .599 lift on each side. I think the Gx3 has around .610 or more which could be the difference and with a thinner gasket it would be close.
Old Apr 7, 2006 | 10:32 AM
  #44
ringram's Avatar
Just a FYI on this. I received my Dart 205's today and the stock GM 5.7L MLS gasket fits the chamber size exactly. I recall seeing that the chamber was larger on an earlier post. Perhaps dart has fixed this. These heads were shipped 24th March from summit after being on back order, so are probably part of the latest batch.
Finish is good, some casting flash here and there, nothing major.
I think Ill just bung them on and see what happens. Looks like around 11:1 on standard engine.
Old Apr 7, 2006 | 11:13 AM
  #45
vettenuts's Avatar
I am just curious, can you measure the chamber width? Mine came out at around 3.96", slightly large than the stock bore. I just went with the 6.0 GM MLS gaskets as the stock was slightly smaller than the chamber if I remember correctly. Patriot distributes this gasket with their heads as well.
When are you installing? With luck, mine will be on this weekend and I should have pushrods by middle of next week. And the weather is getting better after tomorrow as well.
Old Apr 7, 2006 | 12:24 PM
  #46
hawk232's Avatar
The 205's actually measure 64-64.5cc and the 225's measure 63.5cc. The chambers are just a tad smaller then the gasket.
Old Apr 7, 2006 | 12:44 PM
  #47
Lift has little to do with it, its duration and valve events that matter. But my guess would be you would have to notch the pistons on a x3 with thinner gaskets.
Old Apr 7, 2006 | 02:48 PM
  #48
john59's Avatar
Installing Dart 225's this weekend with G5X3 on 114, as per Dart, GM head gasket #12498544.
I'm going to check valve clearance to see if i can mill. also told me to use Autolite 3934 Plugs,i'm going to cross ref. this to an NGK.
John
Old Apr 8, 2006 | 08:59 AM
  #49
ringram's Avatar
Interesting the box says 62cc. If they are 64cc then thats fine. As for chamber width they are just under 4" so likely to be the same size as before then. I must admit I wasnt looking with a micrometer, just lined up the gasket on the head and it felt to the touch bang on.
Mine wont be on till later in the month.
Old Apr 9, 2006 | 11:55 AM
  #50
Kraest's Avatar
Good job, mang
Old Apr 9, 2006 | 01:38 PM
  #51
vettenuts's Avatar
So did I screw up, I went with the 6.0 gaskets part # 12589227
Old Apr 9, 2006 | 02:07 PM
  #52
TRW427SS's Avatar
No but, there is no reason to use a larger than stock bore head gasket in this with the Dart heads.
Old Apr 9, 2006 | 02:33 PM
  #53
vettenuts's Avatar
The reason that I did was the Darts I have measured 3.96 on the chamber, the stock 5.7 gaskets measure 3.93 so I would have gasket hanging into the chamber. Now the gaskets are back from the bore taper at the top. Not sure which situation is better.
Old Apr 14, 2006 | 04:09 PM
  #54
Malihoochie's Avatar
Sigforty - How's your doing? Any new et's? I spoke to Terry at Futral yesterday and your car came up in conversation - that promted me to ask you.
Vettenuts - Is your stuff together yet? I am feeling challenged as the king of procrastination. LOL
Old Apr 14, 2006 | 05:01 PM
  #55
Sigforty's Avatar
No new times yet!! I am waiting to get some time to hit the track. As far as driving everyday the car is getting alot better gas mileage on interstate. I was doing 29 to 30 while travelling at 75 mph.
Old Apr 14, 2006 | 07:31 PM
  #56
WS-Sick's Avatar
The Dart's are looking better and better as the days go on. I've seen pretty much only good thinkgs about them and for the price they can't be beaten as far as I know.
Old Apr 14, 2006 | 07:38 PM
  #57
vettenuts's Avatar
Hoping for start tomorrow. I had a small problem, I will shoot you a PM on it.
Old Apr 14, 2006 | 10:52 PM
  #58
Kraest's Avatar
Telly?
Old Apr 14, 2006 | 11:31 PM
  #59
1LOUD98's Avatar
No he is right Terry,the other guy working there!Whats up with you Mike(this is Telly)
Old Apr 15, 2006 | 04:40 PM
  #60
Kraest's Avatar
Nada, mang. Just workin like crazy! I tried callin the other day. I'll try again on Monday
