rwhp converted to flywheel?
Old Apr 12, 2006 | 05:34 PM
C.W.A's Avatar
Default rwhp converted to flywheel?
I'm putting 583hp down to the ground what does that say about the engines horsepower level?
I calculated about 636hp what's your guess!
99FRC CORVETTE M6
Old Apr 12, 2006 | 07:05 PM
FUN LS1's Avatar
Maybe as high as 670, but probably not with M6.
Old Apr 12, 2006 | 07:10 PM
V8pwrdz28's Avatar
one calculator i used said 685flywheel.
Old Apr 12, 2006 | 07:12 PM
TryingT/A's Avatar
I thought the standard for loss of hp through the driveline (fbody) was:
m6< 10-13% loss
a4< up to 15%
Vettes lose more through their driveline, so it's probably more like 17% loss for you.
670 is probably the closest guess of your flywheel hp
Anyone else use this as a guide?
Old Apr 12, 2006 | 07:13 PM
V8pwrdz28's Avatar
i thought is was 17-20% for A4 and 15% for M6s
Old Apr 12, 2006 | 07:17 PM
TryingT/A's Avatar
for vettes right? But i can beleive the same for fbodies as well.
Old Apr 12, 2006 | 07:18 PM
Ksett's Avatar
99FRC CORVETTE M6
I have a Z06 and what most people lose on the C5 Z06 is 12.5% rule of thumb on the Z06 Forum.
Old Apr 12, 2006 | 07:19 PM
V8pwrdz28's Avatar
thats what i have always heard at least.
TryingT/A's Avatar
so a 15% loss, I'm at 460 bhp. Is that correct?
Old Apr 12, 2006 | 07:22 PM
TryingT/A's Avatar
anyone with a good rule of thumb?
I know a stock ls2 in a c6 will dyno about 330rwhp on dynojet, that's way more than a 15% loss on an m6
Old Apr 14, 2006 | 03:27 PM
jRaskell's Avatar
330rwhp is a 17.5% loss on a 400 crank hp engine. a 15% loss would put you at 340rwhp, so I wouldn't exactly say it's way more.
Old Apr 14, 2006 | 04:41 PM
WAHUSKER's Avatar
I have always heard 15% for an M6 & 17% for an A4. So back figuring it (1 / .85 = 1.176 x 583) you'd have ~685 at the motor.
Old Apr 21, 2006 | 03:50 PM
C.W.A's Avatar
new dyno number 602rwhp, that should = 692rwhp flywheel. is that correct
Old Apr 23, 2006 | 04:19 PM
1999 SS's Avatar
f-body with an m6 is 15%. at least thats the way ive always heard it.
Old Apr 23, 2006 | 07:28 PM
gtodoug's Avatar
I've always heard 15-16% for the solid rear M6 f-bods and 16-17% M6 GTO's with independent rears.
Puts me at 1/.831.2048...x540rwhp=650.60236fwhp
dougie
Old Apr 23, 2006 | 08:07 PM
Mike 01WS6's Avatar
I think a lot of these losses are over exaggerated. If someone does a back to back comparo of engine vs. chassis dyno's, I'm betting you'll be surprised.
Old Apr 23, 2006 | 08:19 PM
gold86vette's Avatar
Still wondering why % are used. I wouldn't bet on a % being accurate.
Example 1 a big block blown alcohol car that makes 2000 hp at 7000 rpm with a manual- alcohol cars have no radiator thus no water pump or other accesories besides the blower itself vs.
Example 2 a small block with all accesories and an auto making 500 hp at 7000.
example 1 : with 15% loss = 300 hp loss when compared engine dyno to RWHP
example 2 : with 17% loss = 85 hp loss when compared to an engine dynovs rwhp.
thats a joke. %'s just dont work.
I would bet all accesories add up to about 40+ hp and the auto trans would steal 60 or more unlocked at 7000 rpms. VS. a manual like a lenco which would rob very little at 7000 rpm. Nevermind driveline losses.
Old Apr 23, 2006 | 08:40 PM
oange ss's Avatar
% is linear across the curve, the more you make the more gets lost as heat buildup in the motor and driveline...and it could take upwards of 300 hp to drive a blower that big at that hp level
Old Apr 24, 2006 | 12:01 AM
Are you kidding?
An engine dyno accounts for the blower loss. Are you telling me it doubles its penalty once installed in a vehicle?
NOT!
%'s only work when calculating air temp differences and compression changes.
Old Apr 24, 2006 | 04:52 PM
oange ss's Avatar
how does an engine account for blower loss ?
