What kind of numbers will I put up???
Old Apr 12, 2006 | 06:39 PM
765joey's Avatar
Default What kind of numbers will I put up???
Hey guys I'll be goin to the dyno soon and just wonderin on your thought i will be puttin down, and poss. some rough ET times. 94' camaro conv. LS6 motor, custom grind comp cam 540/540 lift 232/237 dur, 112 Lobe, All comp Valve train, custom cold air, Mac mid Length, LS1 edit, TTB, Ported throttle body, cut out, 40 ser. Flowmaster, Msd plug wires, B&M shifter, Spec stage 3 clutch, 4:10 gears, 315 drag radials, lower control arms, stb. Any advise and #'s would be appreciated, Thanks
Old Apr 12, 2006 | 07:29 PM
Ksett's Avatar
That's an odd cam so it would be hard to say since I've never seen anything with that low of a lift to compare. Is there any reason why you chose such a low lift?
Old Apr 13, 2006 | 09:19 AM
765joey's Avatar
I got it for $140.00 new and a set of comp 918's for $80.00 new. That's pretty much only reason i went with it. I was wantin somethin around 580 or more lift, but i could not pass up the deal. The cam really surprised me, It pulls really hard with that duration being decent size.
Old Oct 19, 2006 | 08:31 PM
slmdLS1's Avatar
what did you dyno?
