LS2 Stroker low torque numbers
Old May 4, 2006 | 06:17 PM
=ZoomZ='s Avatar
I have the new AFR duel springs on my AFR 225's and was planning on going with the .040 head gasket ,, am i going to have issues running a 650+ lift
with those springs and stock lifters ?
Old May 4, 2006 | 07:18 PM
JakeFusion's Avatar
Super Hulk Smash
Those are some of the best springs out there. The stock lifters may take offense at such an aggressive lobe. So, I'd look into some Morels. Sure they cost a fortune (buy the Lunati branded Morels for $130 less to save some cash), but you can have them rebuilt down the road for a nominal fee.
Old May 4, 2006 | 07:30 PM
=ZoomZ='s Avatar
Can i use that same profile with less lift ,, like a 643/646 ?
Old May 4, 2006 | 08:02 PM
JakeFusion's Avatar
Super Hulk Smash
I don't think you should overlook the XE-R lobe. It's still a really fantastic lobe that will be a bit more aggressive off the seat than the LSK or XFI and aren't so much smaller in the 240s at .200" to make a huge difference.
You could go with a Comp XE-R 244/248 .612"/.615" 113+3. It'd work very well with an 11.8:1 SCR.
Lobe numbers are: 3732/3734.
I think your current cam is too big for your stall, also. A 4000 stall is more appropriate with a 248 intake duration in a 408, IMO.
Old May 15, 2006 | 02:30 PM
CLHAKA's Avatar
Default good call Jake
exactly my combo, runs good.......waiting to break-in before hitting the dyno!
Old May 15, 2006 | 02:40 PM
CHRISPY's Avatar
I take it the pistons have a 12cc dish and not dome correct? Your comp should be in the 11.2-11.4 range if you are using a 12cc dish. (depending on gasket)
I would play with timing and AF in the mid range some more.
Old May 16, 2006 | 01:03 PM
steveo346's Avatar
wow this thread is very informative, this is what a tech forum is all about
