Trailblazer SS Tuning
Old May 5, 2006 | 10:31 AM
2xLS1's Avatar
Dan, I'm not saying you did any thing funny or intentional to start with low baseline #s. So far in this thread, we have 2 real world tuned TBSSs, one did 331/347 (tuned by LS1speed) and yours did 336/352. Those are pretty close. But because of a vendor on another forum promising 40 hp gains with their mail order tune, I've been asked by 2 different TBSS owners if I could get them a 40 HP gain with a tune like that one vendor is promising. One was the owner of the TBSS in the graph I posted. Do you think that vehicle could gain 40 HP with a tune? That would put it in the 365 HP range. I don't think so. Could it reach the 331/347 ~ 336/355 range? Probably so. That's the only point I was trying to make here. Unfortunately some people will only concentrate on the # gained figure they read rather than the final #s.
Old May 5, 2006 | 10:53 AM
BIGBOS's Avatar
I'm having a CAI installed soon, and then it will go on the dyno for a pull or two to make sure the AFR isn't too off.....
So I will let you guys know the results
Old May 5, 2006 | 11:03 AM
2xLS1's Avatar
Please do. We had some real interesting results doing things like removing the air cleaner and removing the plastic piece in front of the MAF on a few pulls on the TBSS we dynoed. Losing between 20~25 hp and the A/F going WAY rich.
Old May 5, 2006 | 03:32 PM
BADSZ28's Avatar
So these run 13.9s with that stock RWHP then gain 30-40 on just a tune? Wow can't wait to see someone tear into one with mods. Can you say family haul'n lightning killer? How much ET do you think is lost in an AWD model?
Old May 5, 2006 | 05:50 PM
obZidian's Avatar
not sure but 12.6 with a tune, cai and ss3600 is doable.....
not huh?
Old May 5, 2006 | 07:41 PM
BADSZ28's Avatar
Wow. Too bad I dumped all this dough into the Z. I could of had a 12 Sec daily driver that can tow a boat. Oh well. imagine what it would do with a KB or Whipple. 11 sec, boat towing DD.
Old May 5, 2006 | 11:45 PM
obZidian's Avatar
Right, but i think it would only that a nice set of heads and a "docile" cam, like a cheatR cam, keep the manifolds and you should definitely be there.
My quest is how well will it do with a smaller stall or even a stockish' stall.... will need to up on the power but she should definitely run real sweet with a h/c.
Now imagine a blowen 382/370, 9.0:1 CR with a turbo/Kenne Bell on top.
I would like the kenne bell for the TBSS.... that would be a great DD and like you said, tow a nice size boat!! Let see that silly Jeep SRT-8 tow a boat, the most it would do before ruining the trans would be a cart full of groceries!!
Old May 8, 2006 | 03:01 PM
Dan Millen's Avatar
LS1TECH Sponsor
I guess I have to disagree with you, cause the truck we did here picked up over 40 horsepower with a tune. I can tell you that our dyno showed 40 horse difference in the same conditions within about the same time frame. I never said that the truck would go to 365 hp, but our truck here based at 285 hot and then after the tune (again it was hot) 330's.
Thanks
Dan
Old May 9, 2006 | 05:58 PM
TonyGXP's Avatar
mine (2WD) dyno'd at 326/330+ after my Wester's Garage Flash tune (15 pulls & 4 different tunes) we got 352/370 on different runs (3 in a row) truck made from 347-352+/ 363-370+ my graphs are hard to read, but I willtry to post them again ( cant get the dam "bitmap" image right)
also my truck ran 13.5's all day long in 40* weather and good air, best of 13.49 @102+ (highest MPH was 102.5) with a 2.02 60' bone stock..
in the heat, before the dyno session I had a tune in there with only 10/10 HP/TQ gains over stock (proven on the dyno) in 75* weather & bad air (DA was 2200') and went 13.52 @102.54 with a 2.05 60..in some good air and weather, it should be in the 13.3's maybe better, nothing more than a tune..(factory replacement K&N was in there since new)
Last edited by TonyGXP; May 9, 2006 at 06:15 PM. Reason: attempting to add dyno sheets
Old May 9, 2006 | 07:06 PM
2xLS1's Avatar
Thanks
Dan
What exactly are you disagreeing with? Are you saying 285 RWHP is a typical base line number for a TBSS?
Old May 10, 2006 | 01:42 PM
Dan Millen's Avatar
LS1TECH Sponsor
I guess I got out that you didn't think there was 40 horse in a tune? (typically I don't either) If you think its possible, the there is no disagreement. If you don't, then we disagree.
Thanks
Dan Millen
Livernois Motorsports
313-561-5500
Old May 10, 2006 | 03:57 PM
  #32
CRASH 02's Avatar
Dan I am not doubting your information at all. If it helps any that is my dyno chart that 2XLS1 is posting. If you look at the run number you can see it is run #6. That is the 6th and final pull that was made. All pulls were made back to back. The first run the SS downshifted so the numbers were off on that pass. It actually made more hp on the last run than the second run. Runs 3-5 were made trying different things with the air intake. So I guess mine more power hot. I have yet to see a stock 2WD dyno less than 320. I don't know that I have seen any with muffler only dyno though.
2XLS1 I am waiting with money in hand for my extra 40hp from my tune.
Old May 10, 2006 | 06:17 PM
  #33
2xLS1's Avatar
Thanks
Dan Millen
313-561-5500
I'm saying I don't think there is 40 rwhp in a tune starting with a typical baseline. Don't know any other way to put it. It's looking like final #s in the 330s is what you are going to get.
Crash02, show me the money...
Old May 10, 2006 | 06:25 PM
  #34
silverTA2002's Avatar
Bottom line....... TBSS gains a lot of power from a tune.
My brother gained about 30 rwhp from a Predator tune on his.
But, when vendors start promising 40 hp + for everyone.......... They're feeding you the same crap thate EVERYONE trying to sell you something is feeding you.
TYPICAL gains and AVERTISED gains are tell two very different stories.
Take the best #'s you've seen, then multiply by 50% to get a realistic idea.
If every ls1 car started with 325rwhp stock, and lid gave you 10hp, cold air 15hp, catback 15hp, headers 40hp, tune 20hp, intake 20hp, MAF 15hp, ported throttlebody 10hp, pullies 5hp.......
That's 475 rwhp with just bolt ons!!!! (560hp at the crank!)
Get the idea?
Old May 11, 2006 | 12:19 AM
  #35
Nickn20's Avatar
Originally Posted by REDWS6ROCKET
that is amazing!
"Manual transmissions impress high school kids, automatics win races.......screw the high school kids."
Cute sig.
And Holy ****, is that THE Dan Millen? lol
Old May 11, 2006 | 11:51 AM
  #36
LivernoisMotorsports's Avatar
I agree, that probably not every truck will see a 40 hp gain, but in this case, that vehicle did see and honest 40 hp gain, the dyno didn't lie and we did two pulls back to back just to be sure. When people call us asking for different products we offer and how much power they will gain from these products, we can give numbers we typically see, but don't guarantee numbers since every vehicle differs.
Rick LeBlanc
Old May 11, 2006 | 02:36 PM
  #37
TeEnAgE pHeNoM's Avatar
Check out www.trailblazerss.com. There is actually one running low 12's and there is also one running 11's. These things cut awsome 60' times with a tune, converter, CAI, and a nitrous kit. Like 1.5's and 1.6's. Thats one fast SUVette
Old May 11, 2006 | 09:53 PM
  #38
Dan Millen's Avatar
LS1TECH Sponsor
Its fine, I really am not gonna go any further, but we did see the gain and that was all I was stating, and given some peoples tuning cababilities, I don't usually say 40 horse from a tune. It was actually amazing to me but the facts are the facts. I have no reason to lie. Now if I said this thing make 450 to the tires I would hope someone calls me out...
I mean don't take this the wrong way but, sometimes I wonder why we go on the message boards at all, it seems like if you tell the truth people don't believe you. Would it of been better if I went on here and completly lied and said it only had a 10 horse gain? It didn't, it gained what we said it did, bottom line. Anyone is welcome to come here and watch this truck on the dyno.
It leaves me kind of puzzled, what should I do next time we some gains that are not the norm?
Dan Millen
Old May 11, 2006 | 10:03 PM
  #39
cantdrv65's Avatar
Thumbs up
Dan Millen
I dont think you did a thing wrong. The truck was obviously running into torque management issues which the tune solved.... Nice work. People just love drama on tech...
Old May 17, 2006 | 10:49 PM
  #40
VTODD's Avatar
I am gonna side with Dan on this. I just had my TBSS dynoed today on a dynojet and it only baselined at 287hp and 299 tq. 3 pulls all within .5 hp.
GM apparently left alot on the table with these. a good tune could be getting close or at 40hp gain setting it at the 330/340 mark.
todd
