LS1Joe New Dyno Numbers
Old May 19, 2006 | 06:35 PM
SlickVert's Avatar
Joe, now that’s what I like to see!
I love how flat your HP line is from 6,000 to 7,300rpm!
That’s gotta to pull like a Freight Train man!
Also, nice improvement from the vacuum pump.
Bob
Old May 22, 2006 | 10:04 AM
dug's Avatar
dug
when you going to Joliet?
Old May 22, 2006 | 10:20 AM
speedracer5532's Avatar
How many pounds of vacuum did you pull with your vacuum pump?
Old May 22, 2006 | 11:53 AM
Mike TexaSS's Avatar
8 Sec Tuner
12-14 INCHES of mercury.
Not psi.
Old May 22, 2006 | 12:05 PM
Not psi.
So you are saying 6-7 psi of vacuum you got 11 rwhp. I find that alittle hard to believe. I could easily see around 20 psi of vacuum you get 11 rwhp. You can run 6-7 psi around on the street normal all the time. If you did actually get 11 rwhp at 6-7 psi then turn it up to around 20 psi (around 40" Hg) and see what hp gain you get.
Old May 22, 2006 | 01:18 PM
BADSZ28's Avatar
Joe,
Nice numbers! What size tire you run? What rpm do you shift and trap?
Thanks
P.S. We all know there is more to a cam then durration. What lift, LSA and LCA does that thing have? I am glad to see cam only record chasers going at it. Especially M6!
Old May 22, 2006 | 01:21 PM
ls1 joe's Avatar
We saw 15 psi and that is exactly what we are shooting for on a stock bottom end.
Joe
Old May 22, 2006 | 01:23 PM
ls1 joe's Avatar
Originally Posted by BADSZ28
Joe,
Thanks
28X10.5X15 and I shift around 7400-7600 depending on what I set the shift light at. I usually trap right when the shift light comes on. Lift is around 620/625 and the duration I have not told anyone as of yet. Still my little secret.
Joe
Old May 22, 2006 | 01:26 PM
BADSZ28's Avatar
Wow you spin that thing high! I would be affraid the bottom would let go. I am nervous about spinning mine to 7k. Can't wait to see some times on that.
Old May 22, 2006 | 02:04 PM
Joe
If you got 11 rwhp at 15 psi that sounds about right. I have heard of 15-20 rwhp at 20+ psi of vacuum. I just thought that gaining 11 rwhp from 6-7 psi of vacuum was alot.
I am waiting on my vacuum pump now and am just curious of your results.
Old May 22, 2006 | 04:15 PM
xfactor_pitbulls's Avatar
I was going to ask how many inches as well, crazy that the vac. added up to 11whp. Impressive.
Brandon
Old May 22, 2006 | 05:00 PM
  #32
cws T/A's Avatar
what track you guys run at ,Houston raceway Park ? I want to see this
let me know when you go , after work ill be to the track
Old May 22, 2006 | 05:02 PM
  #33
ls1 joe's Avatar
Yes we usually go to HRP but the track has been less than par lately. I think the next outing is our trip to Columbus Ohio in two weeks for our next NMCA race.
We will be in Joliet the last of July.
Joe
