Dominator 427 Goes 614 rwhp / 555 rwtq
#41
Originally Posted by mikey
We re-dynoed the car today with a sheet metal intake and it went 674rwhp / 549 rwtq. The intake extended the rpm band to 7000 where it started to roll over. We lost a little bit of torque below 5000 rpms.
This fella just finshed installing his full cage and has it certified so now we are looking for some cooler temps then we hit the track.
I will print a graph and post it shortly.
Mikey
Mikey
Peace
#50
LS1TECH Sponsor
Thanks for the props guys. The manifold manufacturer said we would gain 50-100hp. We've all heard that before but I was very pleasantly surprised when we were finished. I also went with an SD tune. The throttle body is a 105mm Accufab with no IAC provision so getting this thing started when cold takes some patience.
This car is a 100% drag car running race fuel. We are working diligently on weight reduction.
Erik: My car is finished finally running the exact same combo as before except 6 more cubic inches with the new RED block. I wish I had more time for the car but it just sits on the trailer Someone will give it a good home.
I've been real busy guys. Hang with me, I'll get some photos and the dyno sheet posted as soon as I can.
BTW, I'm looking for a test mule for a new 450+CI LS7 race engine
Mikey
Mikey
#53
Mikey
Mikey
#59
Collections Hold
bs
Originally Posted by mike c.
mikey- do you think a ported ls7 head will make more power then the et head? the talk is,the ls7 unported is a good as any et head,port it and it should do better,right? what about the ls7 intake?
#60
LS1TECH Sponsor
As soon as I get the heads I can form an opinion. The GM heads are a real nice piece except for the less than stellar exhaust port but that doesn't bother me a bit.
