Heads/Cam #'s......LOW!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I recently had my SS dynoed with my new heads cam combo, I put down only 385HP/357TQ, which seems really low to me, I was hoping for over 400 RW atleast. Granted it was almost 100* in the building. Mods are ARE Stage 3 ported heads, 2.05/1.57 valves, 10.9:1 CR, F13, LS6, MTI TB, ASP pulley, QTP LT's, Mufflex ORY, Mufflex 4" spintech single outlet, Moser 12 bolt, 4.10's with Denny's NR DS, tuning with HP Tuners. I've heard of guys losing power through the 12 bolts, how much are you losing? AFR was at 13.0 across the pull.
Are you M6 or auto?
Also what type of dyno was it? And where any correction factors used? If they where then outside temp should only have minimal affect on the actually final result.
A 12 bolt will zap some power due to increased roational mass, but in all honesty I think far too many people play this for more than it's worth.
Obvious things to check are how does the car run and drive? Have you had time to take it too the track yet? Are there any issues with the car (KR, miss-fire, etc.)
First off you need to establish IF the car is underperforming. Going to a different dyno and/or real world performance tests should highlight this.
If there still appears to be an issue then you need to track down what it is. A weak spark or lack of fuel, compression leak or installation issue.
Thanks for the replies, it's an M6, the best I've had a the track is 12.27@116 with a 1.89 60ft with M/T ET street radials dead hooking. When I drive the car I feel like it doesn't have the power it should, I feel like it should have more. I have no KR, I logged all the dyno pulls and showed no KR. It was a Dynojet dyno, 300bhp, what do you mean by correction factors? Well when I talked to ARE about buying heads, they were the one that recommended the heads for my car, and I told what cam I was buying and they said that it would work fine with my car, and I also talked to futral back when I bought the cam and gave them the specs on my heads and they said that the cam would work fine with the heads, but of course they could just be telling me that to get my buisness, but I hope not.
Here's the graph, maybe it has more in it, I have a few buddies that are going to help me tune it some more so I may squeeze out some more in it.
http://www.fastrides.com/photos/hard.../original.aspx
LS1TECH Sponsor
two things i see right away are that it peaks kinda early and should have it a little richer than 13.1a/f from what ive seen 12.5ish is where most n/a cars perform best .
the early peaking could be starvation or cam timing maybe.
also if you have the top quilty gas we have here (10% ethanol) that kills power too
so I should lean it out a little bit? I installed the cam and lined the timing marks up dot to dot and I didn't log my duty cycle, I will make a few more logs and see what my injector cycles are at.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by lilbuddy1587
IT'S NOT TUNED ?
There's your problem......You can't skimp on the tune man, you just can't! You're asking for trouble AND are leaving a **** load on the table in terms of hp/tq with a setup like that!
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
