Stock Cubes, NA and 500RWHP, Possible?
Old 06-26-2006, 03:55 PM
lilbuddy1587's Avatar
Friend here in AZ on a stock bottom end running TEA 2.5 ls6 heads, custom EDC cam built to the heads spec, FAST, full bolt ons minus EWP(Verbs old setup) through a 12 bolt and 3.73's ON A NITROUS TUNE put down 492/423
Old 06-26-2006, 04:30 PM
gillbot's Avatar
Originally Posted by theblur98ss
I sure hope anyone that spent the money for a 500hp car isn't running stock rod bolts.
Not everyone has bottomless pockets.
Besides, this wasn't a question of can the stock rod bolts hold 500, it was can you GET TO 500 with stock sized motor. The topic just kinda skewed off for a second.
Old 06-26-2006, 04:36 PM
300bhp/ton's Avatar
Originally Posted by gillbot
It seems as though with the usual H/C and bolton packages start to fall off at 450RWHP. I was just wondering if anyone got there without going radical.
I'm sure 500rwhp is possible but it would depend on several factors.
I highly doubt that a 500rwhp setup is all that friendly to drive and maintance/reliability must suffer at that state of tune.
Plus you'd probably need a really high CR and high octane fuel to support it.
But mostly I bet it's down to dyno operation. Non-SAE corrected figrues could be noticable higher, also graph smoothing (or lack of) can easily show 20rwhp too high.
Also Dynojet Dyno'd tend to be inertia dyno's and read comaritively high compared to load bearing dyno's.
Example:
500rwhp Dynojet would be about the same as 468rwhp on a Mustang Dyno.
Old 07-02-2006, 08:56 PM
Dave D's Avatar
Hey guys- not to jack the thread, but am considering getting a forged 383 package prebuilt for under $4000. Would a N/A 383 package be able to hit 500 rwhp without power adders?? Gillbot, from what i have found, you can easily get a forged 383 motor for $3500- $4000 without a core exchange! I am thinking that is even better than forging your motor or rebuilding it when the time has come. What do you guys think??
Old 07-03-2006, 02:19 AM
'Trust''s Avatar
I thought the 01-02's had weaker ones.
I'm only spinning to 6800.
Sorry to veer off topic. 98's have weak rod bolts, 99-00 are decent, and 01-02 are the stronger of the group, but still should see much higher than 6500 to be safe.
Old 07-03-2006, 03:07 AM
verbs's Avatar
Originally Posted by 11SECDWS6
You need a solid roller to get there.
That's BS. My 2 year old hydraulic heads/cam package is making 490rwhp on 10.9:1 compression through a 12 bolt, 18" wheels, and 4.10's. Bumped up to 11.3:1 in Texas w/ 93 octane which we don't have would give about 500rwhp. Cam is a 236/244 .630/.630 113LSA on TEA Stg. 2.5 LS6 heads
Old 07-03-2006, 04:41 AM
Already posted above you my friend
Old 07-03-2006, 06:02 PM
gillbot's Avatar
Why buy a 383 for $4000 when you can get a 402 or 408 for the same price?
Old 07-03-2006, 06:03 PM
viewsonic's Avatar
I have a stock cube LS2 (364)
And I should be running 500+rwhp in a few days
Old 07-03-2006, 06:13 PM
gillbot's Avatar
I should have specified LS1.
I thought there were already stock cubed LS2's there.
Old 07-03-2006, 07:24 PM
Smartass6885's Avatar
Thats just for the short block. Plan on atleast another $2k for the H/C and other supporting mods.
-Blaze
Old 07-04-2006, 10:35 PM
  #32
stik6shift93's Avatar
I wouldn't expect to make more peak horsepower with a stroker, more torque and area under curve though. Adding bore is what gives you more power. There are a few out there who have done 500rwhp, stock rear end, ewp, fast intake....all the little tricks are needed to get there. With all the new heads out there now i think it may be a little easier to get there. As far as the highest stock displacement, i believe futral put down 550rwhp with a high compression solid roller motor, that's the highest i've seen on stock displacement, with a 10 bolt 560-565 would probably have been possible.
Old 07-06-2006, 09:57 AM
  #33
CARTEK Racing
WS6TransAm01's Avatar
Originally Posted by sickss228
CARTEK 4x 507.9RWHP daily driver and the cam is smaller than T-REX! My setup made 472 on a fresh rebuild pulling 1 in vaccuum because I had stock bellows, getting an updated tune soon and I should be over 490RWHP
Thanks for the mention.
That is my car: 507.9RWHP and 433.6RWTQ with a hydrolic roller cam, stock LS1 bottom end with 63K on it and ported LS6 heads. This is through 4.56 gears in a 12-bolt as well.
Compretion is just slightly higher then stock due to the heads being decked to be strait.
Old 07-06-2006, 10:04 AM
  #34
CARTEK Racing
I drive it all the time, to school, to the shore, to dinner with the GF etc.
I run premium pump gas, 93 in NJ and have a slightly higher then stock CR. right around 11:1 - 11.25:1
Graph smoothing was "5" and the 507.9RW was SAE corected
Im an not trying to be a dick, just saying that with the right parts, and the right tuner it can be done reliably, safely and effectivly.
Old 07-06-2006, 01:03 PM
  #35
HAULNTA's Avatar
Originally Posted by WS6TransAm01
...that with the right parts, and the right tuner it can be done reliably, safely and effectivly.
I agree.
Old 07-06-2006, 06:21 PM
  #36
gillbot's Avatar
I knew it COULD be done, I'm just curious what it takes to get there. From what i've read, you have to go pretty far to get there but 400-450 with a good H/C is rather easy.
Old 02-13-2007, 12:01 AM
  #37
00turboT/A's Avatar
Originally Posted by matt346ls1
I think that the 500rwhp cars are on friendly dynos.
Matt
100% AGREE
Old 02-13-2007, 02:42 AM
  #38
mcamarols1's Avatar
ive must of been on a mean one numbers in sig
but im happy and thats all that matters, i race on the street/track not on the dyno
Old 02-13-2007, 03:20 AM
  #39
NOS USER's Avatar
gillbot : I think with TFS heads + Ven.. Custom Cam + 90/90 ported intake & all bolt- ons get ya in 495-510rwhp range ...try to search man .
Thanks.
Old 02-13-2007, 07:11 AM
  #40
miami993c297's Avatar
Power number in my sig, plus a respectable amount of torque for a 346ci...
And Yes it's a DD!!!!
Christian
