Dyno operator/equipment errors possible?
Just curious who here has had there Car run wierd on the dyno, yet run fine on the road or another dyno? Can the dyno be hooked up wrong? Can haveing the wires they use to read rpm etc make your ignition misfire,as there wires were right on the DELTEQ?, ASR(traction control) on, E Brake on etc etc. Just curious as I am trying to find out why my car ran LEAN (according to the tailpipe AFR readings, 14 to 1), yet dumped black smoke on 2 different tunes. F/P made no difference either.
Car was 12.9 to 1 on another dyno with bung in behind header for wideband, and I lost 25 rwhp and 60ft/lbs of torque with this dyno.
My TTS datamster lodding software shows no signs of detonation and the O2's read around 900mv at WOT, and no black smoke etc or pinging.
Do you have a wb? Maybe do some late night hwy blasts to get a real world sample of wot AFR. If you need it, you can borrow my LC-1 for the check.
But, I do have a bung on the right side, and I will be back in a few weeks, as I am in Washington state right now working a boat.
Can you pm me your number etc?
FWIW, my car blew some smoke at 12.8 - 13.0:1 on the dyno. I would think the smoke wouldn't be as visible on the hwy at speed. You should've seen Charlie's smoke screen when he dynoed NA with his nitrous tune!
