480rwhp+ Magic Stick 4 Camshaft, PRC Stage 2.5 LS6 & Fast 90 Resullts!!
Old 07-11-2006 | 07:07 PM
John02SS's Avatar
Curve looks pretty good! Good job fellas! Are the numbers SAE, STD, or uncorrected? It doesn't say on the graph.
Old 07-11-2006 | 10:05 PM
1MEANGTO's Avatar
Wow what awesome numbers!!
I may switch to this cam with my new ls1 366 combo
Old 07-11-2006 | 10:30 PM
Photochop's Avatar
Nice dyno numbers, now get that car to the track and bust off some high 10s!
Old 07-12-2006 | 09:20 AM
lt197formula's Avatar
damn nice numbers
Old 07-12-2006 | 11:00 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Guys this combo used a stage 2.5 cylinder head. As a result this car required us to cut the pistons. You can use the Stage 1 LS6 with the ms4 & leave the pistons uncut, but we wanted max power. The stage 2.5 heads flow a little more air thanks to the bigger valves. Combine that with the .030" we cut off the heads for more compression & you have a healthy little combo!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-12-2006 | 11:52 AM
Tri5Nerd's Avatar
Default SCR and DCR
What are the numbers with this combo? Since most talks lately are about having the right cam/head combo, we should also know the gasket size, SCR, DCR and quench if this combo is to be duplicated.
Old 07-12-2006 | 12:17 PM
JakeFusion's Avatar
Super Hulk Smash
Static Compression Ratio 11.65:1
Dynamic Compresion Ratio 8.58:1
This is if the cam is ground with 2 degrees of advance and assuming 0.032" quench with .040" gaskets. Also, it assumes a .080" flycut (approx 1cc).
Old 07-12-2006 | 12:25 PM
gvzo6's Avatar
how much did you have to take off the piston?
Old 07-12-2006 | 01:46 PM
1badV6's Avatar
Would like to see some cam only numbers with bolt ons. Preferably in a six speed
Old 07-12-2006 | 02:26 PM
mudflap1989's Avatar
Me too
Old 07-13-2006 | 12:26 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
These valve reliefs were about .080" both sides. It didn't need that much to clear at minimum PtoV specs, but a little extra don't hurt either.
I think we've done one or two MS4's in cam-only setups on minimal bolt-on type street cars. The MS4 will definatly take advantage of the ported heads though and thats what most of my customers have opted for on our installs.
Old 07-13-2006 | 01:42 AM
  #32
verbs's Avatar
badass!
Old 07-13-2006 | 03:37 PM
  #33
98Grnz28's Avatar
That's some good numbers. I been wanting a magic stick. Maybe I can get one in the near future.
Old 07-13-2006 | 11:34 PM
  #34
qwikz28's Avatar
i cant f'n wait for my ms4 to come in...
if i'm not mistaken this car was also running 36# injectors
Old 07-14-2006 | 11:01 PM
  #35
Black98Z28's Avatar
Eddies car will be here in Albuquerque. I work with him and have known him for a while. We are at a 5600ish elevation. Our cars get nailed with the air and it sucks bad. 485 would be plenty to run low 12's high 11's here with a good launch...
Glad you got some mods on the SS Eddie! Great numbers! We should go to the track sometime and see how she does! I have the same Heads on my car
My car is currently down at the momment. I believe i spun a rod bearing or a main bearing. motor is out and going to the machine shop. I might be ordering a 347 shortblock or 402 from TSP. Possibly some more, like a FAST setup. We will see.
Old 07-15-2006 | 12:27 AM
  #36
Reject's Avatar
sorry to hear about that senior Chris
Old 07-15-2006 | 09:41 AM
  #37
pdd's Avatar
pdd
thats impressive with 4.10's
Old 07-15-2006 | 11:28 PM
  #38
HOSS's Avatar
Were those STD or SAE numbers, and what kind of numbers are you seeing with the cam only setups? If those are SAE numbers, those are pretty damn nice!
Old 07-16-2006 | 02:26 AM
  #39
Chris81's Avatar
Nice numbers!
What octane fuel?
Old 07-16-2006 | 11:01 AM
  #40
miami993c297's Avatar
Hi Jason
- 1 ) At what volume the PRC Stage 2.5 LS6 ended cut 0.030 ?
- 2 ) What head gasket did you use for this combo ?
- 3 ) How much the piston are out of the hole ?
- 4 ) How many cc to substract from the flycutting ?
- 5 ) What is the ICL on you new MS4 ?
- 6 ) Are the PRC Double Spring shimed on the INTake side ?
Need to figure those questions before going further with this combo....
Christian
Quick Reply: 480rwhp+ Magic Stick 4 Camshaft, PRC Stage 2.5 LS6 & Fast 90 Resullts!!
