500 Horsepower???
Engine:
ACS# 12,376 of only 14,907 made.
- LS6 Aluminum engine block
- LS6 Composite intake manifold
- Absolute Speed Stage II ported heads with 987 double valve springs and titanium retainers, Ferrea valves, 2.02 intake and 1.60 exhaust.
- 10.9:1 CR
- 224/224-duration camshaft
- Quick Time Performance stainless steel long tube headers
- Under drive Pulley
- 3 inch exhaust
- High flow mufflers with stainless steel tips
- Ported throttle body
- High flow air box and filter
- Hardened push rods
- ARP engine bolts
Other:
- Sub frame connectors
- Lower control arms
- BMR torque arm
- Hurst shifter
- JL Sub in JL Stealth Box with amp
- 18X9.5 inch Chrome Z06 Wheels
- New BFG G-Force tires.
Did late 02 TA's really come from the factory with ls6 block and ls6 intake??
I've done a little research and dont believe the car to have 500 hp at the motor but was just hopping to get a little feedback from some people. Thanks
500HP at the crank is acheivable with those parts. Would really only need 430rwhp or so, and that should be pretty doable.
how about this stuff?
Is that all good?
The LS6 cam comments weren't to you, but the guy that replied to you.
Also, don't fall for the hype about the LS6 block. Really doesn't mean crap. And to second the board, all 2001 and up cars come with the revised intake, a.k.a the "LS6" intake.
Looks like a bunch of quality parts, too. I'd say give it a shot! Good luck!
And as far as the Absolute Speed heads go, if they are 243s (LS6), then they should make very good power.
