mustang dyno vs dynojet
There is much confusion by dyno customers and operators when it comes to correction factors for elevation and atmospheric conditions. Not using correction factors or the wrong ones will cause dramatic differences in dyno readings, skewing the results from hour to hour, day to day on a given dyno or from dyno to dyno, thus limiting the real value of dyno testing and tuning. Today the dyno profession is like the automotive industry was in the 60s, there were no agreed to standards and proceedures for the measurement and advertisement of HP and TQ. Like then, trying to compare readings from brand to brand was most difficult. However, now that most brands are getting into computerized load control, it is possible that we could have a standardized proceedure, such as using a controlled RPM acceleration sweep rate of 300 RPM/second for HP/TQ measurements. With that, getting the correction factors correct and getting each dyno company's engineers to use a certified physics manual stating Sir Isaac Newton's laws could help solve a big problem.
werd! there are like 10 DJ v/s MD threads if they would search. also you could google the same questions and come up with some documentation.
