TEA 215cc Trick Flow Dyno numbers and graph
what is the price tag on the Trick Flow heads, concidering 2.08/1.6 valves and to be fitted on a 346ci solid roller engine, and a fast question with it, i have a custom pistons that have a 2.08/1.6 pockets and can handle up to .700 lift that is designed to ls7 heads, will it be ok with 12 degree head and .660 lift of cam
The head should clear the valve reliefs on your pistons, but how in the world did you end up with 3.90 bore pistons with a 12 degree valve angle? As I don't know of a LS7 head that will fit that bore size. I will make a quote and PM you the price. Thanks!
