Livernois Motorsports Stage 2 Heads and Stage 2R Cam Graph
Originally Posted by cws T/A
Nice Sleeper Vette
Originally Posted by Cgillies86
I wonder if I would gain any if I upgraded the injectors? I am running the stockers right now. Anyone know if there are any gains from upgrading the injectors?
1 Post
Originally Posted by lilbuddy1587
I'm sure you might, but your tuner should have been able to see if you were running at or over your max duty cycle of the injectors. I'd upgrade to some 30lb SVO's if I was you, just for peice of mind.
Originally Posted by allngn_c5
I don't think you are much beyond your 80% duty cycle of your Fuel Injectors. If you are a few % points over no worries, but if you are at 100% you should definately run bigger ones. I have read about numerous guys on here running much higher fuel pressures with stock injectors and being at 105% or more and no one seems to be complaining about their cars performance. With that being said I am surprised that Livernois didn't suggest you upgrade your FI's Dont you have GM 28.8's since its a 97 vette.
He should be fine with the Head/Cam Combo he has...however a few more bolt-on's and he will need to upgrade. I have the 26#'s in right now an am sraying 150 shot with a handfull of bolt on's and Im just fine. Ive sprayed a 185 shot and didnt go lean so I think CGillies will be fine
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I assume you 2 are coming to Milan this Thursday?
1 Post
Stage 2.
WHPLASH- Its been privately rented out...
Or is coming out even an option???
Customer appreciation??
#33
How much to get in on the action??
#34
why did you shut it down at 6700? looks like there is still more out to 7k?
what is your lsa? we have pretty much the same cam. you should be seeing higher numbers both hp and tq. my numbers in sig and thats through a 12 bolt and 4.10s.
jmho.
Congrats tho.
-brandon
jmho.
Congrats tho.
-brandon
#35
jmho.
Congrats tho.
-brandon
jmho.
Congrats tho.
-brandon
#39
get 30#s in there. that way your not running at a 100% duty cycle from 4k+.
best of luck to you. keep me informed of any track numbers, thats where it counts.
-brandon
-brandon
