F-11 cam results on stalled A4
Originally Posted by Sprayed1998
on tires youll run bottom 12's with that set-up
Originally Posted by K9 Pusher
I am assuming you mean street tires by "tires". If my car doesn't run at least an 11.7 on my shitty Nitto DR's I will personally drive it off an overpass on my way home from the track. The footage of this will be prompty posted in the Multimedia Section by my wife immediately following her 24 hour grievance period.
Let us know the outcome, and good luck!
I had the same cam in my 99 when it was cam only. Only difference is I didn't have a ported TB, and I had an ls6 intake and stock '99 heads, and the TCI 4400 convertor. It put down 348 rwhp unlocked and went 11.85@115 on 255/50/16 mt et street radials, 11.99 on 315 nittos, same trap speed on both.
Guy that had the car before me had a 3600 convertor in it for a while and gained 3 tenths going from the 3600 to a 4400. That cam (well most cams) like more stall speed.
Good numbers though, it may go the same times mine did with a better 60' (my best was a 1.74 on the mt's and a 1.78 on the nittos)
Originally Posted by hawk232
that should deffinatly get you in the 11's, hell my m6 with 370 rwhp went 11.89 with a 1.61 60'
Originally Posted by camaro98z28
I agree, I put out those number with a TR 220 114 cam. Might need a better tune???
Originally Posted by lilbuddy1587
Not everyones car is the same nor is every dyno. I'll bet that he runs mid-high 11's @ 114-115
Went to the track today, best I could manage was a 12.28 @ 109mph. 60ft was 1.68. Time and MPH are down from before the cam. Hoping it is a tuning issue. It was hotter than hell at the track so I am sure that plays a factor as well. Needless to say, I'm pissed and a bit disappointed especially since the track was hooking so damn good.
#33
No codes showing. I'm calling my tuner tomorrow to see what he says. The car feels good on the street but at the track, not so much. A couple of folks at the track told me it didn't sound like my shifts were firm enough, A4 sounded like it was granny shifting.
#35
#36
Originally Posted by 2001 White Ws6
What was your 1/8th mile speed?
Also did some checking on the Density Altitude for the day I ran the car. Normal altitude for the track is 187ft. DA that day was almost 2500ft. So I think in some better weather I will definitely see some 11's. Just have to be patient.
#39
Not yet, if this son of a bitch doesn't pep up in some better weather, I'm selling it!
I suggest looking into HPTuners, or EFILive. It sucks having to rely on other people to make your car run the way you want it to.
