Low '02 Z06 Dyno Numbers
All pulls were done on a Dynojet 224x
May 5th, 2006
Mods: Blackwing Filter
Temps in the mid 90s
Best Pull: 327hp, 313tq
________________________________________
Sept 2nd, 2006
Mods: Blackwing Filter, TPIS Longtubes, Corsa X-pipe, NX Wet Kit, TR6 Plugs (gapped at .040")
Temps around 100F
Green: 330hp, 323tq (no spray)
Blue: 427hp, 453tq (100 shot, 52N/26F pills)
Red: 465hp, 500tq (150 shot, 62N/31F pills)
I've heard that these cars run very rich stock, but this rich is normal? AFRs were measured at the exhaust tip.
Only a gain of 3hp and 10tq from the longtubes and Xpipe?
Not sure what is with the hiccup between 3100-3500rpm. But the fluke on the green line was the wideband falling out of the exhaust.
Any thoughts?
I, also, have heard that most 02+ Z06 put down around 345-360 stock.
Oh, and I have no cats.
you should get a tune, that would be your best next step, but i would decifer what is wrong with the car before anything else. Same dyno??? I would maybe try another dyno facility and make sure they monitor IAT, knock retard, and total timing during the pull as well as AFR
edit: the first dyno pull is uncorrected (which could be high- low depending on elevation and temp...) and second is STD. Your dyno operator needs to give you SAE #s before you do anything else, so we can see what the actual gains are. If it was 90 degrees and uncorrected #'s, it is very possible it did 320 stock (uncorrected) If it is the same dyno/ same operator, tell him to start looking for a new job.
My next step will definitely be a tune at a different shop (this one specializes in imports). I'll have them monitor what you listed.
I'm in Florida which is about sea level and the first dyno the temp was in the 90s. What does uncorrected #s mean? Or should I ask what do they need to be corrected for?
Thanks for the advice!
Can't believe you'd actually spray it with the motor that bad to start with
I dont realy see any knock retard on the dyno graph (no sudden dips), but you will want to monitor O2 readings, Knock Retard, and timing for starters with your next dyno.
What was up with the A/F reading in the second graph (N/A pull in green)?
